TrustFire TR-3T6 heads for truck offroad lights.
i am curious of the ideal of using two, or four modified heads from Trustfire TR-3T6 3-XM-L lights. i don’t have one of these lights to see what output they have, but i have various SRK lights and other 3-emitter lights of different brightnesses and tints of probably similar output to the 3T6, and thought about the the idea of using similar lights in modified form for off-road lights on my truck from winch guard.
knowing the 3T6 can use up to 3-18650s, so the driver can handle probably the 12 –14 volt DC supply of vehicles, then modding the heads to be more water tight and sealed and adding mounting brackets, i wonder how these would work for snow-plowing uses and off-road use. Using the stock driver would even allow 3 brightness beam levels ( along with the strobe, etc) by turning the switch of and on quickly, and as long as the lights modes were in “sync” with each other.
do anyone know of the best priced T36 lights, or similar low cost lights of similar output and can run of the 12 volt supply ( lights that used 3 cells is series.)
There was a post on the bargain thread about them being $20~ on Amazon. I’m not sure about the technical side but two of these would be ample for offroading and four would be for fun.
Would be cool to build a “Light Bar” that uses 15 of them across the roof. :bigsmile:
