"tomorrow" is today.
Unfortunately I haven't been able to mod it yet. Cereal_killer generously sent me some 10mm BLF pcb's that I was going to use in this light, but for some reason I didn't get them. I have replacement PCB's being made by Oshpark right now.
The first barrier is this bit of plastic and brass spring cap. Grab the brass with needle nose pliers and yank it out. All the nylon ring does is hold down the contact plate.
That gets you to the good stuff. The contact plate and the driver. The contact plate is in the background. It used to have a spring. I'm feeling lazy, but I believe that last time I measure these, the contact plate was 16mm in diameter, and the driver was 15mm. The driver floats, and only passes electricity through the wires. There's a positive and negative wire, and the two LED leads. But wait, shouldn't there be two more wires for the switch? Let's look at this side of the driver first, then we'll look for the missing wires on the other side.
Nope, they're not on that side either. That wouldn't make sense anyway.
We better look at the switch and figure out what in tarnation is going on. The top of the outer ring of switch and the white ring is supposed to be flush with the surrounding metal, but I didn't feel like pushing it back in because I'd have to push it back out, and it's quite a tight fit. Ignore the groove at the 2 o'clock position. I had started trying to cut the head apart to see what's inside before another member gave some tips that helped me take it apart without the carnage.
When the switch is pulled out, you see a tiny spring that the black wire from the driver was attached to. Note that this design actually includes the spring wire mod that many of us like to do, too bad they used hair thin wires. There's a hole in the white plastic, and through here you can insert a rod to push out the switch. You can also see two threads holes that were for the clip. Apparently this light isn't very waterproof thanks to these holes, especially if you remove the clip like I do.
This should explain things if you haven't already figured it out. On the right side is a metal tab that makes contact with the body of the flashlight, by which it connects to the negative side of the battery. Electricity passes through the un-anodized threads. Then the spring in the last picture sends electricity from the switch to the black wire that goes to the driver.
Here's where the mcpcb is mounted. The top of the pill is only 9mm in diameter and there's a groove right under where the LED goes for the leads.
The mcpcb is 8mm in diameter. I hope 10mm Sinkpads can be trimmed down, but sadly I can't try it out because I lost some of those too.
Lastly, the tailcap. It's just a wide spring making contact with bare aluminum at the bottom of the tailcap. I might copper electroplate both so I can do a spring wire mod from the top of the spring directly to the tailcap. Copper plating will eliminate the difficulty of soldering to aluminum.
