trying to consolidate all ZeusRay posts
Thanks Hank.
That is true. I put silicone based heat sink compound on the o-rings, but that is not like having the metal touch. Maybe that is one reason some zoomies, such as the CNQ host and the TrustFire Z8, have screw threaded zoom, in addition to more stability in places like bicycle handle bars. Some have a wire ring instead of an o-ring, but that is still not much contact. Making a snug fit would be expensive in production, because the machining process would have to be slowed down to reduce thermal expansion. But there was a post about filling the gap with copper foil, wrapped around the body.
@hank
This link for only gets me to this
Well, I tried to kill it again.
Put in a fresh cell, cycled through the modes several times and it worked fine. SO I left it running for about 15 minutes until it got hot and then tried cycling through the modes again. Once again, no problems. Let it run again for 10 minutes and again cycled through. No problems.
Swapped out batteries for fresh ones and again repeated this cycle. Still alive and kicking.
Either:
  1. I got a good one
  2. The cells I am using are laptop pulls. Perhaps they are just not strong enough compared to the 3400 panasonics you guys are using.
  3. Mine were shipped to Israel. Maybe due to location a seperate batch was used…?
works for me — for the list comparing various zoomies
EDIT:
— that’s Comment #219 — if the link only takes you to the top of the thread, look in upper right corner of each comment and page down til you see it
Sorry hank your link doesn’t work at all for me, it only goes here and on that page, the first one in this thread i can find that post that you are referring to.
can anyone else try it? maybe ask sb the admin, why the link doesn’t work maybe it is a bug.
Direct post links depend on the comments per page setting you are using (shown at bottom of a BLF page). Dunno if the poster or you ar eusing the non-standard setting.. I never know, never can get them to work. I usually ask/beg for a post #.
Sorry if this has been asked already.
Zeusray vs Convoy S2/S2+. Which wins?
Also, are there good alternatives for up to $10?
I tried to googling up dealmetic since Vince hasn’t responded to any if my PMs ,and their website is nonexistent has anyone else tried their website lately?
Worked fine earlier today.
I tried earlier and it keeps coming ssl server error would you be willing to do me a favor and post the link for me?
thanks for explaining why the link didn’t work for everyone.
D’oh.
— that list of common zoomies is in this thread at Comment #219 — if the link only takes you to the top of the thread, look in upper right corner of each comment and page down til you see it
It doesn’t work now.
Easy way to check if it’s your problem or global: Dealmetic.com down? Current problems and status.
The “NiceWell Enterprise” web link used the same server as DealMetic, I assume the’re different heads of the same body.
But NiceWell is still up: http://www.aliexpress.com/store/1006220
As noted earlier above, they’re selling the same zoomie: http://www.aliexpress.com/item/Free-Shipping-So-Cool-2000-Lumen-Mini-Portable-Zoomable-CREE-XM-L-L2-LED-Flashlight-Torch/2009131742.html
and other products that have the ZeusRay logo: http://img.alibaba.com/kf/HTB1DmI8GVXXXXbYaXXXq6xXFXXXB.jpg
(Although as we know, just having the logo doesn’t mean having any particular level of quality inside)
So, maybe the DealMetic side is just having maintenance.
We can hope.
EDIT: DealMetic is back up, according to Dealmetic.com down? Current problems and status.
I pulled out the driver from mine, stuck the tip of my hemostats through the wire holes and push against the brown plastic thing until it popped out.
I decided to use a dedomed XM-L U3-1A to sacrifice on the unit I got that had the press fit or pasted shim; also added some more paste on the star, cycled through each mode 5min each on a UR18650FM and everything is good. I haven't tried the other one I have with the floaty shim, but I'm sure that one is going to die.
Thanks Tom & hank, now i finally found the post.
It’s up and running now
Does anybody have a suggestion for a replacement driver (inexpensive) for the bad batch of these?
I’ve had great luck with mine so far. Stupid bright on IMR compared to my C8/S2+. Best $8 I’ve spent on flashlights so far. Highly recommend … oh and definitely dedome!
