I’ve go a few 46950’s and 46110 but little in the way of a good meter. So I ran a comparison for what it’s worth. Using a Keweisi USB meter with 5 digit current recording I got the following result.
- Sofirn SP36 with 3 NCR18650GA’s batteries discharged to 2.6 volts, 8286mah at 5.00 volts to fully charged to 4.2 volts.
- Astrolux EC06 with 3 Molicel P45B’s discharged to 2.6 volts, 11051mah at 5.00 volts to fully charged to 4.2 volts…
- Lumintop Mach 4695 with 1 4695 discharged to 3.0 volts, 26306mah at 5.00 volts to fully charged to 4.25 volts.
- Lumintop Mach 4695 with 1 46110 discharged to 3.0 volts, 31523mah at 5.00 volts to fully charged to 4.25 volts.
Many 46xx cells list their voltage at 4.25v to 2.8v. The Mach 4695 won’t charge cells under 3.00v, so in this light it’s to fixed range. I know that the wattage going in is going to have the voltage lowered and the current raised. I just don’t have the efficiency rates so this is for pure observations and speculations. Charging was at 2.4 to 2.65 amps loss to heat should be very low. All said the 46110 to 8.5 times the charge as a Molicel P45B’s and 11.4 times the charge as a Sanyo NCR18650GA’s.
