I'm trying to learn a bit more about electronics to hopefully build some basic circuits in the future...
I would like to eventually use a PWM signal from a Microprocessor to control a MOSFET's gate, in order to regulate current flow.
I am just trying to turn on and off the power in this test circuit. It seems to work... but I cannot seem to get much power through the MOSFET after it activates... does anyone see what I am doing wrong?
I think it is, I ran the sweep up to 50v at one point to make sure… I can see the mosfet switch on, I’m just not getting much power through it, like it has a high resistance…
OK, I kept thinking the problem had to be drain-source resistance, but I didn't know how to adjust for that. It wasn't obvious looking at the FET parameters. So I opened the library and found the IRF7401, swapped it in and what a difference...
