【TS10 Max】TS10 Max available now on wurkkos brand day with dark blue oxidize
Good to know, hopefully it will have performance close to a modified FW3A in that case.
What sort of driver is it, for low modes does it use a 7135 chip like the TS10 and TS25, or is it something else?
The new connections for the inner tube look a lot better than the old style, hopefully the risk of wearing out or having an unreliable connection is much lower.
Nice! Its an 18650 light that should be good!
FET+7135 right now cause the buck driver still in testing need to figure out some bugs, :cry:
10 Thanks
I see, hopefully the buck version will be buck+FET so that it also has an uncapped maximum current on turbo.
It would be appreciated if the buck drivers were also available for sale individually, so that people can upgrade their first-version lights too.
I have bought a TS10 Max as the price was very affordable, hopefully it arrives soon.
@Wurkkos
Thanks for all the info above!
Do you know when the black version will be available?
I do like this blue one, but I would be willing to wait a bit more for the black one !
other color will be available next month
6 Thanks
Would you concider a shorter 18650 tube for batteriers without charging? I know that it works with normal batteries too, but the TS10 is known for being tiny. A battery tube that is a little shorter would be better as it allows the flashlight to be as small as possible.
Can I reuse your images of the Max for friends? Thanks.
Thanks Terry. Looks good. Mine has shipped…
:+1:
Stop asking for other metals and different tube sizes, before you even have the original light, Johnny mac was spot on. Stop being flashlight karens. Love y’all enjoy your week.
12 Thanks
I have to agree. Everyone has their personal likes and dislikes, but maybe we should get the original light fully sorted before asking for changes. For instance, I think getting the buck driver properly implemented first is a bigger deal than any other changes.
As to the tube length, I can’t see 1 to 5 MM change in length making a huge or even noticeable difference in feel or ease of carry. But, yeah, that is just me.
13 Thanks
Thanks Terry and Wurkkos for testing things thoeiughly before sending them out! Look forward to a buck or boost driver version. I never got a FW3A or the one with the Lume1 driver, so if you can make one with Sft25R leds as an option and a regulated driver that would be awesome. Don’t need onboard usb c charging!
6 Thanks
Someone got TS10 Max with stock Wurkkos battery and report that the light did shutoff when using turbo.
He tried unprotected flat top battery and the light work just fine.
Not sure how widespread this issue will be. But worth noting
Massive :+1: for Nichia 519a, but I hope 4500k will be offered
Also, like others have said I really prefer boost or buck driver, for runtime. If the light cannot sustain 250-500 for more than 1 hours , I’m not interested
I just got mine today.
I just tried it with the stock cell that I had just fully charged. I only ran it for 90 seconds on turbo (150/150). It stepped down, but did not turn off. Maybe a difference in cell health?
Congrats, mine isn’t expected to arrive until the 5th.
Have you tried to remove the bezel? I assume it’s glued like the TS10, but both mine came apart pretty easy. If you’re able to remove the bezel and have a spare Carclo 105XX optic, could you check if they fit?
Bezel was very easy to loosen. No glue at all.
OOPS, that was the head. Bezel must be glued. It is not going to let me unscrew it easily. At this point I am not going to worry about breaking it loose.
I don’t have the optic that you mention.
As an aside, the tail cap on this one unscrewed easily.
Appreciate you giving it a try.
Was it charged up full before using first time is the big ? here.
Normally they are around 3.80 v if that when shipped.
That’s quite unfortunate, I was planning on taking mine apart to mess with the LEDs (maybe a dedome or swap). Hopefully the adhesive releases with heat.
Is the optic exposed or is there glass to protect it?
