【TS10V3 prototype】Should we continue with the TS10 series~
To me, the prototype also looks like it’s made of copper; in any case, they are photographed at different stages of oxidation, and the lighting is different, too… it’s incredible how copper (and, by extension, its alloys) can change its appearance.
Copper vs… copper
I do not think Red Copper flashlights are made of Alloys
I asked Google what kind of copper is used to make Chinese flashlights..
the answer:
"Chinese flashlight manufacturers use high-purity Oxygen-Free Copper (OFC) or Electrolytic Tough Pitch (ETP) copper, which generally ranges from 99.90% to 99.99% purity…
Popular Chinese enthusiast brands construct their solid copper flashlight bodies using these unalloyed, high-purity grades"
There’s another form of Copper you are all forgetting…
:police_officer:
It would be better if the clip were black, so… black clip please :wink:
No, it’s not pure copper. Look at the pic I posted. The higher quality copper is the V1 which is a deeper red. The copper used for the V2 is more brassy, and is a copper alloy.
I think the AI answer is correct to a degree. Lumintop, my Maratac and many others are probably a pure copper. But I think this light pinkish copper does not look pure. It’s not red enough.
Lovely polishing job you did on your Brass and Copper TS10’s
this thread has some pics of the box labels (due to language translation issues, they dont use the words Brass nor Copper.. I think those would be the English names though):
Im excited about the upcoming Copper TS10V3. :wink:
No my friend, they are all copper. My point in showing is that the darker red one is a V1 Cu, and the other two are the V2 copper. The lighter coloured rosy stuff is what Sofirn and Wurkkos are now using, and my guess is that it contains more zinc, making it look more brassy without being the true golden of brass.
Thanks for the compliment though. All three have amber @Boaz filters on them and are used as candles in flicker mode.
Just about to give them all a polish with Brasso, I’ll do a before and after pic under the same lighting.
I was referring in general to how copper ( :joy: pure copper 99,99 %) can change color in a thousand different ways; but brass (Cu 60-70% Zn 35-40% Pb 3%) , too, can take on truly varied colors, ranging from gold to black.
Why do you think the yellow metal and the red metal are both Copper? Is it based on what you thought you were ordering?
Maybe something is getting confused in translation?
you realize Chinese use the same root word, 铜 tóng, for Copper, Brass, and Bronze right?
to add to the confusion…
what do the boxes say? :wink:
to my eyes you have two Brass and one Copper light in your photo, but in Chinese they are different colors of 铜 tóng, tóng afaik means copper
afaik, the Chinese word for what English speakers call Copper, is Red Copper (hóngtóng, hóng afaik means red)
and the Chinese word for Brass is Yellow Copper (huángtóng, huáng afaik means yellow)
They’re definitely all copper, I don’t like brass lights unless they’re old lamps, I’d never have ordered anything in brass. Brass is an alloy of copper and zinc, so my thinking is that the copper lights we get may have some zinc in the mix. But, I don’t know.
Having cleaned them all, the redder tinge on the older TS is much harder to see than in that pic I posted, I can see it with my eyes, but it’s not showing well under the fluorescent tube in the kitchen.
Gratuitous pic anyway :slight_smile:
do they weigh the same? :wink:
“Pure copper has a higher density (~8.96 g/cm³) than standard brass alloys (which typically range from roughly 8.4 to 8.73 g/cm³ depending on the zinc content).”
the weight difference is relatively small.. not sure if you can tell…
Pure copper is a bright salmon pink. Take steel wool to it under running water to see.
It oxidises in a fraction of a second from salmon pink to “pink copper color” as soon as it sees the first hints of oxygen, then sloooowly starts turning into that polished copper color like on cookware, then a deeper copper color like on a newish penny, gradually fading into a brown like on old pennies, until thoroughly oxidised into solid brown like wood.
They won’t. The V1 is a tiny bit shorter. And, to be honest…I’m not bothered.
We started on copper a few posts above with the machining marks on the very pink looking prototype . And for every me that doesn’t like those brush marks, there will be another that does.
My dad’s hobby was copper and silver smithing, so me and my sis made a lot of enamelled arty trinkets, spent much fun time acid bathing and working through the compounds on the buffer wheels. I like mirror polish on pure copper.
Many would disagree, notably machinists. This person gets it though…
Less gummy too. Most copper will clog a cutter, and brass may clog or clobber a tool (or both) depending on the alloy.
Please stop.
I’m pretty sure that it’s illegal to shove that type of copper into a lathe, spin it up, and cut it. I am positive that it would make a mess that I would not want to clean up.
Gemma/Gemini is a little weird. I tried two others One said C1100 straight-up, the other mention that C1100 was common while also noting, “Page 5 discusses copper types in Chinese: red copper (pure copper, ≥99.5% Cu+Ag), brass (Cu-Zn alloy, 57-70% Cu), naval brass (brass with 1% Sn), tin bronze, etc”. The other concurred that C1100 was common and went down some rabbit holes;
“… the common knowledge is that most Chinese-made “all-copper” flashlights are machined from C101/C102 free-cutting copper rod (easy-machining copper containing about 0.6–0.8% Pb). This allows for fast and clean machining without work hardening. On the other hand, pure red copper (C1100 / JIS C1100) is soft and gummy, making it difficult to machine at high speeds.”
It is worth noting that it does not take much to alter how a metal behaves, whether it’s alloys that only need 0.5% other stuff, or heat-treating, or other porcesses. For Inconel, the chemistry of 625 vs 718 is small but the difference in how they machine is quite drastic. The effects on tool life and cycle time are non-trivial… and annoying.
As an aside, Qwen 3.8 deserves it’s reputation for overthinking. Stick with 3.6 unless you really need what 3.8 offers.
Stop lo dici a tua sorella,stronzo…
