Newbie question: After 2 DIY builds (Convoy S2+ triple and Convoy L6 with Cree XHP70.2), I am wondering about the effect of driving LED’s well past the manufacture’s limits. I’m particularly wondering about the L6 with the Cree. My first LED was defective, but during sorting that out, I measured 8.2 volts across it while in direct drive/turbo mode supplied by two 28650’s nearly fully charged and a Mountain Electronics driver. Cree’s data stops at about 4.8 amps and 6 volts. From some test data on this forum, at that voltage out the driver could be suppling upwards of 15 amps, about three times the manufacture’s maximum. The flashlight is awesome bright, btw. So long as the temperature limits are not exceeded, what effect does this have on the LED? Does it shorten the life? Thank you!
Exceedding Manufactures Specs does shorten the life considerably. You pay for the bright :sunglasses:
That depends how much you exceed it by.
If you exceed it enough it will die instantly.
Over driving will shorten the LED’s life. Usually Cree and Nichia use the rated max current at certain temperature (25C/85C) to get the Lxx (70/80/90) x hours. For example:
Cree always publish their ongoing tests results.
For Cree LEDs you can find the documents in the product library. For Nichia LEDs you have to contact your local Nichia representative.
As general rule: the smaller the thermal resistance and the bigger the die(s), the less susceptible the LED from over driving.
20.000 hours for a flashlight is like forever, it’s not much of a concern. Unless you plan to use the flashlight every night or to make the LED inside your current flashlight for your next family heritage item.
- Clemence
