I recently bought a sportac triple and was a little disappointed to find it was only a single mode. Plus I think I like the beam profile and tint of the mt-g2 P60 I have. So it got me thinking on how to improve the mtg2 light. Well I had a qtc pill (actually 2) that wasn’t being used. But I didn’t want to being running only through the qtc, I wanted full power as well.
My brain has been hurting the last 2 days trying to figure out how to make it happen. I eventually found a switch that made it a little easier than a McClicky. I have a 22650 zoomie host that I use for parts (enter the switch).
I took the switch out of the housing and put it back in upside down. Like this it fits in (SF) C tail caps. In this case it’s an ultrafire C1.
Added spring and qtc pill to the long leg of the switch. A little double sided tape to keep the pill in place (I later realized I should have used more).
For the contact plate I used a copper star with the dialectric layer cut off. I soldered one side to the short leg of the switch. I am hoping the short leg will put up with a little flexing for a while.
From the tests that I did I found I needed more packing around the qtc pill so it could spring back effectively.
It didn’t really work. It was having connection issues and wasn’t smooth at all. I cut a piece of spring from a P60 module, lightly greased it with nyogel and lay that on the star. It seemed to take away the sketchy connection.
If I could’ve got away without using the piece of spring then the tail would’ve screwed on to a perfect depth IMO. I used 2 O-rings in the gap but as you can see there is space for one more. I did put one in there however it would squeeze out when tightening the cap to activate the qtc.
It took some head scratching and it is far from perfect, I mean the whole switch assembly is just sitting loose in the tail BUT IT WORKS! :party:
I can use the twisty, silent and low OR I can hit full power at any time.
