UF-2100 with an optic
So I was messing around with my 2100 the other day and accidently wiped the reflector and low and behold the coating came off. I polished what I had left (brassy yellow metal) and put it back. Turned the beam a funny color. Anyhow from my old parts post ended up with some optics. So I tried one out. I sanded down the retaining rim edge of this optic and stacked it up behind the glass. This let the height be the same as the reflector was. Not sure what the Optic is but it has a small tapered hole through the center.
I will try to get some beamshots in next couple of days. but it seems to me to have a tighter hot spot and be a little bit less floody. One downside is that is has a slightly dark ring about 2/3 out from the center. Tried it outside and not super noticable.
Try a Regina reflector, it has more throw than the stock one
