Is this still a go-to light…? I see all kinds of prices and different lights on ebay…
I am just looking for a decent 18650 light for knock around maintenance work. Should I go with a previous seller for $15-$18….
Or should I go somewhere else…?
Thanks
Tony
I have several of the 50X lights and they are ok, but for a couple of bux more you can get a Solarforce L2m. This light will take 1 18350, 1 18650 or 2 18350’s with the right drop in. The one I am linking here already includes a drop in. They make good drop in’s, not the highest output but reliable.
Convoy S series is a better option as far as customization options (tint/output), thermal management, build quality and consistency. More compact and durable as well.
I would also suggest a Convoy model. The M1 is most similar to a 504b, and right at $20. Or a C8 is a little bigger and a little cheaper. Both are considered higher quality than a 504b. They’re also available at mtnelectronics for the same sticker price, but added shipping cost.
Ok I like it. I figure it will take those 70mm cells I just ordered…
What is with the options?? the 7135 options, the more mah, the more output…?
And which LED do I choose, it’s actually confusing!
Basically I am going to get two, I figure someone at work will pop for them, I occasionally put together a light/charger/battery set for some one who likes my lights.
Should I get the 7135*8 for max output, paired with….which emitter…?
Thanks
I hope so. For cheap edc lights for the ‘common man’ I always get them a 50xb as they are a fair cheaper than the $22 M1’s I bought.
Time will tell if the guys like these better and see value…
We have a new guy starting so I bought him one, and another guy was interested in one… So that one might sit around un-bought… Plus I have to sell a $5 Panasonic cell and a wp2 charger to each shop.
But people are always impressed when I whip a light out. These guys make big bucks, and literally use $5 home depot lights I wouldn’t give my kid… Smh…
I just got them. I think they came in under $22…and you guys are right, WAY nicer than a cheap UF 50x light.
really nice, tight beam. Packs quite a punch and the fit n finish is fantastic!!!
Thanks!!
Tony
I like the 504b (silver) as host for example from dx.com and then adding a custom P60-dropin from intl-outdoor.com. All in all a very good light for the money and it takes rough handling well.
The position of the emitter depth into the reflector will change the shape of the light column. The perfect hotspot is simply a nicely collimated beam. Move the emitter within the reflector, and the beam will disperse.
Or you can just put a diffuser in for a lens. A lot of tips on that trick here in BLF.
