UF900, HS802, 1jc8 and C8
I need help with selecting driver emitter combo for these. I want to play around with red and green emitters. I prefer to stick with single mode high. If some one could going me in the right direction it would be greatly appreciated. Thx
As for the HS-802 it could not get much simplier than this green and red dropin.
I would think a amc7135 linear driver would work good with the single cell lights.
For the UF900, you could replace the LED with one of these.
https://illuminationsupply.com/cree-xpe-red-10mm-star-mcpcb-p-151.html
Along with replacing the driver with one of these.
https://illuminationsupply.com/4xamc7135-14a-3-mode-driver-p-46.html
However you would probably be better off not modding that one. The other ones would be much easier to do.
For 1JC8 you would just need to replace the LED with one of these.
For the C8 we would need to see a picture of the LED to find out how much current the driver is supplying.
Sweet thatnks for the help guys. My C8 is from intl-outdoors Xin TD xml T6 with hi/low modes only
With that one it would also be more complicated. You would just use the LED I linked to above and the same driver. (Although it is 3 mode, if you can wait for ones coming from China you can get 1 mode)
I bought The red drop In mentioned above for the hs-802. It comes with an xr-c emitter and pulled 2.5 amps(way overdriven). Didn’t put out any where nere the amount of light of the xpe. Lasted one minute before the emitter Got crazy hot and desoldered itself from the pill. I pulled the emitter and driver. Put the red xpe and 1.4a 3 mode driver mentioned above from illumination supply in. Not that hard with right equipment. I am very happy with the results. Nice tight hotspot almost, two hours of run time on a panny 3400. A very nice upgrade. I also put the same emitter and driver in a c8. The beam is a little different than the hs-802. It has a slightly larger hot spot and a touch more spill. And again I,ve used the same driver with green xpe and xre emitters with very good results. The hs802 reflector does a little better job with the xre green than the xpe. Hope this helps.
The xin has a great pill. You could leave the stock pill alone and build another one with a bare pill from lck-led.
Thanks guys. Kevin thanks for the first hand info! I will get an order together after christmas.
I am somewhat new to flashlight modification and currently going through the learning curve. I have specific uses for my lights as the choices for commercially available lights with color emitters is very limited. There is only a handful of guys working with these type lights and getting info is tough. So I am learning the hard way, spending lots of money, time, and even burning up and breaking “stuff” to figure it all out. Good luck with your project.
Nice work kevin!
I have done an 2 small sun c10’s one with a xrc red, and one with a xre green. They both work really well but I think I like the red light better overall. The green xre is a direct drive drive pulling 1.6a and the xrc red is using a east-92 (same driver that is in the hd2010) driver and is pushing it at 2a. I have filled the pill on the red xrc with copper and solder takes a while to start warming up. The green xre one has stock pill and the body warms alot faster.
I also have installed a green xre in a jacob a60. It has good spill.
I like the aspherical lights better for hunting with.
Personally I would leave the xin c8 like it is and order a cheap c8 to put a colored led in. The hs802 would be nice with one of the linked colored dropins listed above.
This light appears to be the same light as the HS-802. I would assume it works pretty well given it’s price tag.
Im fairly certain its a UF900 from brinyte. How quick is lightmalls and illumination supply regarding shipping? Is it like manafont slow
i have the light linked above and purchased it from that very same seller. its called the xlr-250 kill light. i bought it in kit form with a green emitter. its very bright. its driven at around 1000mA(1A). it is the same as trustfire usa168, hs-802 even though EWT will tell you different. EWT does add a few shims to focus the emitter before it leaves the factory but thats about it. in kit form, it comes with every thing you need to “get you into” a hunting light. it is expensive but a complete kit and ships from the usa. the lightmalls and manafont hs-802 red, and xlr250red come with an xr-c emitter. you will be disappointed with the red unless you mod it. the green ones are sold with xr-e green emitters. probably not high binned but nonetheless pretty decent. the green lights pick up everything in the air. humidity, dust, snow, rain, mist, etc. but you retain color rendition which helps identify your game. the red doesnt seem to be effected as much and also preserves night vision better. in other words, flick on the green and your pupils contract for a second until they adjust, making it harder to see at night.
i have not ordered from lightmalls but i have manafont. plan on three weeks, if you get it sooner bonus. alot of people have had problems with manafont but i have not. illumination supply is excellent.
Kevin,
FWIW I started out buying the Wicked W400…similar to the XLR250. I bought a green one….pretty dang bright. I dropped that kinda cash before I learned a little bit about the availability of these cheaper lights.
Then I ordered a Brinyte BR01 with red led. This thing is pretty bright too, and in fact I prefer it over the W400. Somehow the green light has more glare (for me) and I feel I can see things better with this red light. Anyway, just thought I’d mention it in case you think the LED itself is worth finding or you just decide to get a whole new C8. I wish I had not bough the the W440 and just bought a red and green Brinyte.
Kev what did you do with the xrc red emitter? Did you keep or replace? Ive been using white light and its been working fine but i would like to play around with red and green. I might just need to put an order together tonight… All this light talk has my wallet burning a hole in my pocket
@ wahoowad…. that br01 is the same light as the c8 i have two. they are really good lights. i’m using them as test beds for future mods. i’m building custom made c8 pills for all my hunting buddies.
@gr8lite…i took the xr-c red emitter out of the brass pill and shit canned it, along with the driver. then installed a 1.4A 3 mode 7135 driver from illumination supply along with a cree xp-e red from them also. the driver has mode memory, whatever mode it is in when you turn it off is what it turns on in. turn off in high…starts back up in high…etc. i use low to get to and from a stand and then depending on how close the game animal is away, use med or high to finish the job. if the animal is really close i’ve found you can burn ’em in the eyes and spook them.
i know a few guys that are using red lights to scan and white for the shooting. works for them. i hav’nt tried it yet.
welcome to the addiction. these bonehead hunting light marketers are out of their mind what they are charging for so called hunting lights.
sorry about the long winded post but its christmas eve and i’ve been sipping a few fine craft brewed IPA’s. :beer: :beer:
I got my order from lightmalls rather quick. Ordered on Xmas eve and I had it 12/31 via DHL @ 1:00pm EST. I picked up another HS-802 with green emitter and bought another red dropin as well as a pressure switch. The green is terrible while the red on the other hand is much better than I expected. Easy to ID at 125yards. Im going to check out illumination supply and order up some green and red emitters along with new drivers and see what happens.
How do you know what driver to pair with an emitter? Is it just the peak output amperage?
Just pick what amperage you want to drive the emitter at and what options you want in a driver. I like to drive my emitters over the max that cree states especially in these kind of lights that don’t get used all the time and usually shorter amounts of time when used. I also have started liking the red lights better then the green in flashlights and hog lights
though i do agree with what apt323 says. i would add this info. look at the cree datasheets and study them. then look at some of the testing other really smart members have done here, such as this More Emitter Test Results (xpg2, xpe2, mtg2) Updated 11-12-12.
using the information gathered from these real smart guys in my opinion driving the color emitters red and green xp-e much past 1.4A just creates more heat and not more light. the green responds better because of the higher forward voltage. the red has a much lower Vf and the driver has to “bleed off” that xtra voltage as heat.
as far as modes most hunting type guys like one mode in high. keep it simple. however, i have been playing with high-med-low 1.4A driver with mode memory.avialable from fasttech or illumination supply. i’ve been using the low mode to get to and from a set. high to scan and medium when the predator is coming in close.
I agree with you kevin but I use a simple direct drive driver, that way its single mode. The two small sun c10’s are direct drive the green xre is pulling 1.6a on a good battery and the red xrc is pulling 2.0a on a cheap ultrafire red and gray.
A couple of weeks ago was out deer hunting and when it got dark i pulled out the red xrc and the deer were at the feeder still. This does leaves the feeder and walks around the edge of the field and i held it on her the hole time (probably like 5 minutes) she didn’t ever seem to spook or care about the light. Its my first real long experience with my colored lights (all the hogs have left our lease since its been so dry)
for sharing that story. that is my experience also. the red light does not seem to spook deer very much or any other animal i’ve shined it at. the deer get get real nervous and don’t stick around long when shined with the green. the coyotes and fox don’t seem to mind the green at all. some people will definitely disagree with that.
i have not shined any hogs yet. we don’t have many, if any here in ny. and there is no season. yet :wink:
i tried running an xrc red at 2.5A and it got so hot it desoldered itself off the star. so i gave up on trying to push the limits of the little red cree emitters. glad to see you have found a way to make your direct drive set up work. that green xre might be able to take alittle more juice. i have two on the way i’ll let you know how they do.
my uf-t20 green xp-e at 1.4A is putting out about 33kcd its a beast.
