Ugreen 100w GaN charger review [disassembly, oscilloscope, stress-test]
Disassembly, oscilloscope, heating, power stress test and general impressions after a month of using 100 watt GaN charger from Ugreen. If you want to choose a powerful charger for your laptop and smartphone, then I am sure that you should definitely look at this model.
You can buy Ugreen 100w GaN charger at:
➤ AMAZON
Specification:
Number of ports: 4 (3*Type-C , 1 USB-A)
Output power: 100W;
Dimensions: 70*70*32mm;
Weekend
Type-C: 5V*3A, 9V*3A, 12V*3A, 15V*3A, 20V*5A
Type-C: 5V*3A, 9V*2.5A, 12V*1.88A
Type-A: 4.5V*5A, 5V*4.5A, 5V*3A, 9V*2A, 12V*1.5A.
PACKAGE AND APPEARANCE
A hard cardboard box with good design.
There is a choice of “charger only” or “charger + 100w type-C cable” kits.
If you pick full kit, then you get 2m cable. This is good if you plan to power up your laptop by this GaN charger. If you just need powerful and fast charging for your smartphone, then it’s better to take a shorter cable separately
The cable is excellent, long, nylon braided.
The charger itself is made in the usual form of a plastic bar with a plug at one side and charge ports at another.
As with the Ugreen 65w, appearance are impeccable. Plastic does not stink, does not sag. no reason to complain at all. charger looks and feels really good.
Actually, here are both of these models. The dimensions, with almost half the power, are almost the same. The difference is more in the texture, the “rib” of which in the younger model seems to me more attractive. They have the same connectors, I will return to them below.
The main characteristics are duplicated on the bottom side
And here are charge ports
This part is flawless. Again, Ugreen 100w looks and feels great in the hands.
Ugreen 100w charge tests
let`s start with charging protocol support
Type C
I remind you that only 2 extreme USB-C ports give out a maximum power of 100 watts
Hell, yeah, i really like the color carousel of this tester
The third Type-C connector has a lower maximum power, only 22.5 watts. Well, that is
“only” by modern standards, my Mi8 still requires 18w and i believe this to be fast charge.
Interestingly, but it was possible to squeeze out significantly more than declared, almost 28 watts at 9v from this 3rd Type-C port
Though wattage is as promised when i raised voltage to 12v.
USB-A
Simultaneous charging
If connected 2 charging devices at the same time, then the maximum that I could see was 75 + 19.8 watts = 92.8 watts. Also quite good.
Disassembly, heating, oscilloscope
Disassembly
Well, i bet there are lots of people here at forum who know this necromancy stuff like “northern bridge” and “schottky”. i don’t. but my sister husband is exactly “dudefixthisyouranengineer” and closely work with PD. so he did what i couldn’t - disassembled Ugreen 100w GaN charger for review and gave his priceless tech guy comments.
“Here is the screen on the pictures, on both sides, This is good”
“The blue line - insulating gasket , insulates the screen from high voltage, also good”
“Red is the GAN module itself, Ugreen didn’t deceive. Here is the datasheet for it
“Here you can see that the flux was washed badly, it feels like after mounting the SMD they washed it, and when the outputs were soldered, they did not wash it. This is not very good, this flux will then corrode it all, but this is usual story for Chinese with flux like this, you can live with it and have no troubles”
“Galvanic isolation is present in some form, i`d rate it as 3 of 5. That is good by today’s standards, good”
“In these points questions about galvanic isolation arives”
“Well, in general, a solid power supply, they didn’t save on capacitors, the board is made solidly and neatly, everything is glued to the gray snot, nothing falls off”
Oscilloscope
i, personally have no idea. As my dude didnt say anything bad about this, i suppose all these lines illustrates that Ugreen 100w Gan charger works as should.
The stress test was simple. Now I have a colossal, incredibly sized Nitecore NES1200 power bank being prepared for a review (will be released really soon, this is a monster device).
And it can be charged via Type-C, taking exactly 100 watts.
With such power, it takes only 12 hours for Nitecore NES1200 to be charged! So I plugged Ugreen 100w GaN charger, left it overnight, went in in the morning - the charger block had a perfectly normall temperature and did not stink. I checked it several times after plugging in, like after 1st and 2nd hour - there were no reason to worry.
Overall impressions
Excellent powerful GaN charger, which is confirmed by thousands of orders and hundreds of positive feedback at Ugreen 100w product page at Ali. However, I see little point in taking it just to charge smartphones, 65 watt version cost way less and performs no worse (i have this one, so i know)
But! There is one task where Type-C 100 watts will show itself in all its glory. It’s about charging a laptop. More and more laptops can be charged via the Type-C input nowadays. And for most of them, 100 watts will be more than enough. And this eliminates the need to carry a full-size power supply with a wire. If we are talking about some thin model like the same MacBook, then such a set of laptop, GaN charger and good 100w Type-C cable solves all issues. You can charge your laptop, you can charge your smartphone. And all this with a minimum of space taken
Right now I’m typing this review at the Lenovo Legion Pro, a laptop with a colossal power supply unit. And when i go to countryside for “banya and moonshine” weekend session, I don’t take this giant Lenovo native laptop charge with me when!
I just use laptop battery and periodically send the laptop to sleep, to charge it from this 100w charger during this sleep. (Legion Pro is way to powerful even for 100w charger). I`m trying to say that this Ugreen GaN charger can work even for really powerful laptop.
Briefly speaking. Ugreen Gan 100w is an excellent charger in every sense. It honestly provides with promised 100 watts and can do it for hours without overheating and plastic stench.
It looks great and will allow you to simultaneously and quickly charge several devices at once. After a month of use, I have not the slightest complaint. I fully recommend. If you want to choose a Type-C laptop charger, then, i believe you would be happy with Ugreen 100w GaN charger.
Gee…thanks for the review, wondering how this stands up to safety tests.
