I want to buy a headlamp to use during the trail running races at night.
I see the Skilhunt H02 ($ 19.99) and H03 ($ 31.99) but I do not know if there is a better headlamp in relation to quality price.
The skilhunt H03 or H02 would probably work well for your purpose. I have the H03, and I think the H02 is very similar. I don’t think you’ll find a cheaper light that is better. The H03 is lightweight compared to lots of headlamps, which is necessary for running. The beam of the H03 is very wide and uniform and I imagine it would be good for running because as the light is bouncing around the objects on the ground will remain uniformly illuminated. The 18650 will provide a lot of run time (how long do you need it to last?) You will probably want to test the current of each of the modes to determine which mode will provide the run time you need and be bright enough. You could carry an additional 18650 cell if you need very bright modes that don’t last as long.
I run trails and on the street with a couple of headlamps. the skilhunt h03 is great for all your needs and is really good value. the throw is decent. I usually keep the lamp on level 3 the first setting. if the terrain is smoother I will keep it on level 2. I ran with it this morning.
I also use a zebralight h600fc: I like the color tint and beam pattern. to be hones I like the skilhunt better for easy access to more modes.
Armytek wizard pro: Love the tint, very well made but just don't use it much. a bit heavy and the middle modes are too bright for my needs.
For shorter runs (less than an hour) My thrunite th20 is very nice. you could not go wrong here.
thrunite TH20… although I am a backpacker and trail hiker. Not runner.
Something I have always wanted to ask a trail runner… How come they always look so pissed off? They never appear happy, smiling or at least outwardly appear to be enjoying what they’re doing. Of course there are exceptions… I guess a lot of them are training, and are into it the intensity of the moment…??
Boruit RJ02. 9bux at GB, cheap enough to be “disposable” but quite a nice and fairly rugged light (that I use every day), and is unbeatable for the price. See the teardown someone else did to see what made it tick.
I’m always happy when I’m on the mountain but there are moments that we can be down as we race for 20 hours or more. There are several emotions and it is not easy to always be happy. But at least i try always be happy
Lighttbringer
In some races it is necessary to have replacement batteries so the Boruit RJ02 is not for me.
Tnks anyway :+1:
The H03R is also nice, the only thing I would modify is add an AR coated lens
The price, user interface and lightweight definately speaks for the H03
Its not a light meant to run at turbo, as its not eaven reach 3A stock with a high drain cell
I agree about the pissed off look, even on this side of the continent!,
Regarding headlamps I can’t stand the Black Diamond or similar with 3 AAA batteries and the UI, some people dig them I don’t.
Try replacing those batteries in the dark or low light conditions when your tired, wet, cold.
I’m a hiker as well I like the AA size headlamps. AA’s are found everywhere, and I can replace the cell in dark. I have the SkilHunt H15, and the Fenix HL50 each one has plus and minus features. I’m still searching for the “perfect” headlamp to suit me.
I own both the Boruit RJ-02 and Skilhunt H02 headlamps. While I agree that the RJ-02 battery can be easily replaced with another 18650, as a former marathon runner I see two problems with the RJ-02. The first is weight - according to my digital scale the RJ-02 weighs 4.9 oz without a battery versus 3.8 oz for the H02. Second, the headband on the RJ-02 has a large rubber piece that connects the straps to the light. This rubber piece rests directly on the forehead, and gets uncomfortable if you are sweating. The part of the headband on the H02 that rests against the forehead is cloth, and wicks away sweat.
I haven’t seen that episode in many years, but if I remember correctly the shoe lights were for taking out the garbage?? Did he make a running version?
EDIT: I just watched it - I guess if the car battery and headlights came out of a 4WD they would qualify as trail running shoes.
