Got one to see what it was all about…compared to other budget lights…this is OK…but NOT the best…
I would classify this one as a bound for the “shelf of shame”
UltraFire 535 from fasttech
Product specs from website
- Beam range: 500 meters
- Working voltage: 3.6-4.5V
- Head diameter: 3.5cm
- Body diameter: 2.5cm
- Tail diameter: 2.6cm
- Lanyard length: 13.5cm
This is built and about the size of the UltraFire 502b, side clicky and has a novel charge port on the size, I got this to see what it was about and see if it had any internal charge circuitry (it doesn’t!!! more on that later)
Comparing it to a Convoy C8 this thing fails utterly short…
Came to me with a few scratches but that is because it was in the standard fasttech bubble envelope stuffed with alot of other things
PROS:
- budget, for $6.27 it’s incredibly inexpensive
- small size, roughly the exact same size as the 502b
- side clicky
- external charging port (both good and bad)
- decent throw, can get out over 100 yards
CONS:
- hollow pill (incredibly small thin hollow pill)
- side clicky button incredibly sensitive switching modes
- next mode memory (fixable with pencil mark mod)
- plastic reflector
- external charging port (that has NO charge controller circuitry…straight to the battery!!)
- 1000 lumens…YEAH RIGHT!
- XP-E emitter
- Shiny finish
I am not a master of taking pics so you will have to forgive me…and they may be a bit small
XR-E on typical 20mm aluminum star, hollow pill underneat barely ANY lip for heat transfer to get from star to pill
Driver side, extra long spring is to contact the side click module in the handle between the battery and the pill
Driver, 20mm (HI/LOW/STROBE)…missing most of it’s components…extremely thin wires, next mode memory from HELL but capable of doing the pencil trace mod so that is fixed
Not alot of meat in the head area of the flashlight for wicking heat away from a larger emitter, as you can see pill and the head screw down on the end
Odd plastic reflector with 1/2 of it OP and 1/2 of it SMO, came with a few defects in the reflector surface
Now on to the clicky module and charge port
Definitely not going to be a ultra bright power house as the clicky switch itself has very thin leads, only touching some metal tophat elements that connect the battery compartment to the spring for the driver, the biggest concern/worry/gripe is the charging port…it is DIRECT CONNECT to the battery, the center pin + goes right into the module and thru a l shaped piece of metal goes right to the battery connection, ok fine and dandy until someone builds a charger using a standard 3.5mm DC power plug barrel connector and wires it directly to a 5vdc source thinking that’s what it needs to charge…nope…this will push WAY too high power to the battery and NOT stop charging it possibly resulting in a vent!
The proper charge method is to wire a 3.5mm DC power plug barrel connector into one of those small inexpensive USB Li Ion charge modules and charge it that way, any other way will result in VERY bad things happening. This is NOT a safe charging port for the inexperienced Li Ion user…PERIOD!
I would really like to be enthusiastic about this flashlight…but for $6 more you can get MUCH better budget flashlights out there…More or less the first flashlight that I am not wowed by and almost regret getting it, is it useable sure…but there are MUCH MUCH better flashlights out there.
Mod possibilities
A. XP-G on 20mm sinkpad JBWelded to what lip there is, then fill in the hole behind it with silicon to wick away the heat…but to where??
B. 101-AK-A1 driver at 1400mA (max), flash with STAR V1.1 firmware (heck the 2 group 3/5 would be better than the stock driver), mount it to a 20mm adapter insert
Almost not even worth it as the updated parts cost more than the entire light itself
C. The reflector does have the hole for a XM-L but if you run an XM-L at close to 3A it will get way too hot too fast, there is not alot of places for the heat to migrate away from the pill, except down the body towards the battery
I give this a 1.5 out of 5 stars…
