Ultrafire C12 vs Convoy C8
Hello, this is my first post but I have read a lot of peoples reviews on this forum.
I have been looking for a comparison of the Ultrafire C12 and Convoy C8 (both XM-L2 versions) but have had no luck so thought I’d ask here! So, what are peoples experiences/opinions on both of these lights? Thanks in advance!
Convoy is a consistent good quality. UltraFire is a lottery. You can’t really compare it as even samples from same seller may vary greatly in quality.
I’d go with Convoy C8.
Ok good to know thanks… What about flood and throw?
The reflector size is the same, so if they driven similarly and they will have same flood and throw. If one have smooth reflector and other OP than OP will have little less throw and smoother transition from hotspot to spill. Convoy C8 usually comes with OP but some sellers offer different options.
A good thing is, they are both affordable, so you could buy both and compare.
But remember, a torch is torch by and large. If they use the same internal components, and similar physical dimensions. Then they are not likely to be all that different.
Convoy have generally gained a reputation for good quality machining. This makes their torches generally look and feel nice. Ultrafire is more hit and miss, some are great, while others feel very cheapy.
If flood and throw interest you. Then there are some simply rules that may help in your decision making.
Throw (in terms of beam profile) is generally dictated by reflector size and size vs the LED.
e.g.
A larger reflector will offer more throw than a small one.
So with the same LED, a C8 vs a tube style 18650 light will offer more throw by having a smaller tighter and brighter hot spot, but less bright spill beam. The tube light will have a large less focused hotspot and usually brighter spill. Even if both lights have the same lumen output.
Its the reflector diameter than makes the difference here. Reflector depth won’t really affect throw, but can change the area and intensity of the spill beam.
LED size.
As a rule the larger the LED the more lumens it can output, but the lower the surface brightness. And lumens on their own do not equal throw.
This means, for a given reflector size, an XP-G/E or XR-E will normally out throw an XM-L/2 sized LED. The trade off is a smaller hot spot and less bright spill, i.e. lower lumen output.
Reflector surface, such as SMO, OP or HOP (smooth, orange peel, heavy orange peel) can affect PEAK throw numbers, as some light (lumens) and focus is diffused. But the main aim here of textured reflectors is to smooth out the transition between hot spot and spill beam.
Mixing and matching the above can offer dramatic differences on beam profile.
Welcome to the forum logesearle! :beer:
Unless you know a good source that sells good Ultrafire C8, otherwise I would recommend you to go for Covoy or XinTD brand of C8, at least there is no bad clones of these two brands so far. The New version Convoy C8 looks pretty amazing especially at that reasonable price so you might want to grab one. :wink:
Go with the new Convoy C8. The C12 is made of random low quality material, its almost the same light as the old C8 but with more cooling fins, which are useless and unpleasant to hold.
Thanks for the information guys! From what I’ve read the Ultrafire C12 is driven harder than the Convoy C8 so I’m sort of leaning towards the C12 unless someone can tell me otherwise!
I own both, including the newest C12 with the XPL. Yes it is direct drive and will pull just over 3 amps with braiding of the springs and a good battery.
However a Convoy with the regulated driver will pull 2.8 amps all day long on a variety of good batteries, not just low resistance ones.
And the build quality is both better and more consistent.
You will have better results over the long haul with the Convoy.
Convoy beam still looks better even though slightly less amps.
JMHO, your amperage may vary,
Keith
It’s depends on the battery you use. Even though the C12 run direct-drive on high mode but if you put an Ultrafire crappy battery inside it won’t give you >3A of current draw, maybe just around 2A or slightly more. Even if you use fully-charged good battery I still doubt if the current draw can maintain more than a few minutes because of the increasing Vf in the LED and the voltage sag occurring in your battery both due to the high current draw.
Also I don’t know if you are going to mod your C12 or not, if you don’t the output will not be any better due to the aluminium board - dielectric layer to be exact, which has very poor thermal conductivity, thus under high current draw the light output will sag like a falling rock.
And did I mention that Convoy C8 has good modes, while C12 has disco modes with visible and ugly PWM frequency in medium and low modes? :stuck_out_tongue:
So with C12 even though it may draw higher current the light output will drop very fast anyway. Yes you are right that some sources sell C12/C8 with direct-drive driver, but normally we need to do some modding on them to allow them perform as we expected (i.e. DTP board, good battery…). Convoy C8 is really good in every aspects. :slight_smile:
Thanks everyone… Looks like Convoy is the way to go. The bloody NZ dollar has dropped considerably over the last week so I’ll have to fork out a few more $$ for the light now :stuck_out_tongue:
Only problem is the whining sound of their stock driver in low and especially in medium. Its really annoying.
Springs sometimes are vibrating due to too low PWM frequency. There is a easy way to fix this by adding wire (so current will mostly bypass the spring).
That was a good question, I was intrigued by the cooling fins of the C12. My Convoy C8 gets a bit warm after a while, but I am pleased with it. I was considering getting a C12 but the new Convoy C8 has a lot of improvements and adds a fin. I’m not sure about the change in the tail spring.
Mine did that,I took the lense/reflector out and tighten down the pill and cleaned the threads with an alcohol wipe and the noise went away
I got a few c8 conveys( a mixture of smo & op) seem much better made than the ultrafire c12 I have, and the tangs fire c8, pretty disappointed with the tangs fire c8,even the lense doesn’t fit properly
I think the number of cooling fins is not the most important thing. The most critical heat transmission path is where the LED sits on (got to be DTP), and the type of thermal paste used come second. The rest are pretty insignificant in heat dissipation.
