Ultrafire F10 meets a driver that does exactly what it says it'll do. 4.5A
I picked up an Ultrafire F10 from FT. I liked it from the moment I opened the package. Nicely designed and well constructed with thick double o-rings all around. As soon as I saw the beam profile I was hooked, smooth and flawless with a tight perfect hotspot. Runs on one, two or three 18650s.
I took a tail reading of 1.1A running 2 x NCR18650A…(2.2A). Sorry, but I didn’t get any readings at the emitter.
This light definitely deserved an upgrade. If the beam had been ringy or sloppy, I wouldn’t have bothered, but the beam profile earned it extra attention.
I had just recieved a couple XM-L Multi-Cell circuit boards from IOS that claimed 4.5A to the emitter, so I decided to give it a go.
Left: Stock Driver Right: IOS Driver
The driver is taller than the stock, but is doable. If you pull the emitter leads all the way through and cut them to exact length the contact board will just fit. I know doing that and soldering to copper is easier said than done, so I kept the leads long so I had room to play. The contact board ends up not quite coming close enough to contact the pill, but it doesn’t matter because the pill is inside the head with a retaining ring that threads down onto the board and competes ground. I did put some Klapton tape between the upper and lower boards to avoid any shorting.
I was going to reflow the stock XM-L onto copper, but found an XM-L2 U2 already on a Noctigon, so I used it.
I hooked up the DMM, turned the light on high, and got an emitter reading of 4.52A. Wow, I couldn’t believe it. A driver that did exactly what it said it would do. I was expecting 3.2-3.8A. I like this driver! I took a tail reading and got 2.6A with two cells…(5.2A).
I like this torch,and I like this driver…especially when they’re paired up. The stock driver would run on 1, 2 or 3 cells, but this one will only run on 2 or 3.
IOS Driver=4.5A at the emitter…believe it!
F10 2x18650
F10 3x18650
F10 and IOS T10B
This wall shot was taken with an ipad. It likes to pull all the brightest light into a whole. The actual size of the Hotspot is closer to half of that pictured.
Nice mod and report. Thanks for sharing. I see you have an assistant. I have a couple of those very helpful assistants too.
Nice... These drivers (3A/4,5A/5A) seems to deliver. Nice to hear that it is so spot on.. Thanks for sharing the info in the high current driver thread too.
:beer:
I forgot to mention that I didn’t upgrade the leads or add any copper braid to the springs. I got a 4.52A emitter reading without any pampering.
I don’t lose as many components since I got him. I can drop a 7135 chip on the floor, and he’s right on it. :slight_smile:
Which color has the Tailcapboot?
Lemon Yellow.
That looks alot cooler than the Fasttech photos make it look. I was considering that light awhile ago, hard to beat $23. Would you terribly mind maybe givings us a side-by-side comparison with say, a C8 reflector, just for scale reference?
Sorry. I don’t own any C8s to compare it to. I have a couple in the mail though.
After my mod was done, this light got dropped from three feet onto a ceramic tile floor. No damage, and I held my breath while I turned it on. Now I know the wiring and driver installation are solid.
I wonder what’s the cat is thinking in that pic. LoL!
:party:
The cat is thinking, this mod has turned out purrrrfect.
if you remember the driver was 20mm or 22mm?
This is the same driver that I installed.
Definitely need that emitter on a copper sinkpad or noctigon at 4.5A, that pill looks alot like the C8…but looks are deceiving alot of times
The pill is nice and heavy and the head is designed to move heat. The picture in the OP is the stock MCPCB. Everything I do is mounted on a Noctigon or sinkpad. I’ll probably be pulling these 4.5A and 5A large toroid drivers out of my single emitter lights and replacing them with the small toroid 5A versions. The large toroid ones are just too valuable for driving triple emitter lights.
nice driver thank you.i think one with mtg2 will be monster.
