And my U-F10 is further away from stock again. I’m sorry not to have taken pictures , I promise next mod will be with pictures again.
I had already bypassed the 1R5 on the driver but ultimately I wanted this light to throw, and throw in a small light like this for me is a dedomed XP-E2. I have a few XP-E2 R4 3C’s (from intl-outdoor, they are still stocked) and those should give a good tint after dedoming. I ruined one by dedoming it too cold and ripping off the entire phosfor layer (it is a very nice royal blue XP-E2 now :cry: ), an other one dedomed well and indeed the tint is pretty pleasant: slightly yellow 4000K but no green…
A good throw needs a well focused led and the 16mm Noctigon is way thicker than the stock board, it needed sanding down to 1mm thickness :weary: . To do that I soldered a curved piece of solid copper wire as a handle on the wire pads and by holding it firmly with pliers I sanded the board down using the disc sander, keeping the board cool by dipping the board into water after every 6 seconds of sanding. Took 5 minutes of pretty focussed work because the sanding disk was worn down already and needs replacement. The already dedomed led was reflowed on the board, checked for succes with the led tester, and then the board was soldered onto the brass pill.
The voltage of the XP-E2 is high compared to the stock XM-L2 so to get the ideal current of about 2.2A both springs needed bypassing. I kept the brass cap of the tail spring in place, the silicon bypass-wire was soldered in the middle on the inside of the cap so that the spring fitted around it.
The current on a fresh Efest IMR 16340 is 2.3A now, which is slightly too high for my liking but with drainage of the cell this will lower enough. The output in flood of course went considerably down compared to the XM-L2: the led is way smaller and the current too. There’s 250 lumen leftover (still sufficient for an EDC), and of very good tint compared to the stock light. And of course the throw went up drastically: I measured (fresh battery, 30 seconds after switch-on, measured at 7 meter distance) 46kcd.
I hoped for about 54kcd based on an dedomed XP-E2 sk68 mod in the past (that had 39kcd throw, but has a 1.38 times smaller lens than this one), but 46kcd is pretty nice too
