Hey, I’m looking for suggestions for helmet lights for fellow cavers.
The requirements of our unicorn are:
- fairly bright, ≥ 900 lm ANSI
- decent runtime, ≥ 12 h at ~ 150 lm
- concurrent, individually-controlled beams: flood, ≥ 110 ° + spot, 15 to 30 °
- warm light, 3500 to 4500 K, for visual comfort (matched beams)
- excellent colour rendition, ≥ 90 CRI, for photography (matched beams)
- low mass, ≤ 200g | 0.5 lbs, including battery, to reduce neck strain
- high reliability, eg robust, no wires/connectors, good controller, good thermal design
- swapable, generic, internal battery, eg 21700, 18650 (multiple cells is fine)
The ideal specification includes:
- submersible, 1 to 2 m, eg IP68, IP69
- red led, for eg bats
- UV led, for eg minerals
Some good resources: SpeleoDocs - headlamp comparison, Derek Bristol - headlamps
Note that mass and external, proprietary batteries rule out many of the ‘hardcore’ caving lights eg Scurion 1500, El Speleo (disestablished?), Petzl DUO-RL, Stenlight, Ay-Up, and so on.
There are plenty of options for a spot+flood+red (eg Nitecore, Fenix, Olight, …) but I can’t find one with high CRI, warm light — well, the HC65 does have a high CRI led, but it’s a 300 lm auxiliary — I’m hoping someone will point out the unicorn I missed!
I use the superb combo of a Zebralight H604c (4000 K, 120 °) + H600c (4000 K, 17 °) in a bespoke action camera mount: low weight, internal + swapable battery, submersible, nice warm light, super wide + a spot, inherent redundancy, but the H604c seems to be discontinued ![]()
A Zebralight d-series (5000 K) combo (H604d + H600d) looks like the best compromise, but it’s sad to lose the 4000 K, and there’s no red light.
If we relax the dual-beam requirement (colour temperature & rendition are more important), we could also consider ‘floody’ single-beam lights, eg Armytek Wizard C2 Pro Max Warm, Zebralight Fc600c, and carry a backup light (low mass, red led).
Looking forward to your suggestions!
