Unidentified CREE Emitter ?
I tore down a SmallSun ZY-R804 single-AAA twistie to modify it,
first be dedoming the Emitter. the seller listed it as a CREE XP-G, but i noticed somthing looked different than a common XP-G die, i went ahead and Dedomed it in a 50 % solution mix of Premium Gasoline and % 50 mix of Naptha White Gas, and with in 15 minutes i got a perfectly dedomed emitter, but under the mini microscope it looks like somthing i never seen before on a Cree star.
(definitely not like the traditional XP-G series emitters from Cree) This one has a emitter die roughly the same size of a XP-E emitter, but with no visible Lead wires, and two tiny copper-traces across the surface connecting it to the star.
! put the light back together, and the dedomed mystery emitter now has a nice neutral tint, throws much farther, and a sharper hotspot in this tiny single-mode AAA twistie.
Anyone seen this emitter before ? is it a new or odd-ball CREE model, or a different emitter flowed on a cree star ? - as seen in the photos below:
that one looks very close indeed, interesting that the 3535 lay-out is getting the standard. Now for some XM-L alternatives as well :-)
