Unique Fire UF-2220
Hi, I’m new to your forum and this is my first review so don’t be so harsh please.
I was asked to review this Unique Fire UF-2220 flashlight, that I received from tmart.com ( http://www.tmart.com/UniqueFire-UF-2220-CREE-XM-L-U2-13W-1400-Lumen-1-LED-5-Modes-Flashlight-Torch-Black-1-18650_p148210.html )
My previous experience with inexpensive Chinese LED flashlights was not so good but was also long time ago, and these days they came a long way, most of my flashlights now are Chinese so I agreed to do it. My other reason to look at this light was that I always tend to go with the budget prices and this light did fit the bill and was curious to see how useful is this particular light for $22.99 .
The light came in plain white box, no fancy markings and so on, nothing wrong with this if you need a budget unit that one will not keep in the box anyway.
These are the specks of the light, as posted in the website:
Brand UniqueFire
Model UF - 2220
Emitter Type CREE U2
Lumens 1400 Lumens
Power 13W
Bulb Quantity 1
Light Color White
Lightbulb / LED Lifespan 100000 hours
Modes 5
Mode Arrangement Hi > Mid > Lo > Strobe > SOS
Lighting Distance 200 m
Battery Configuration 1 x 18650 batteries (not included)
Input Voltage 3.7 - 4.2V
Runtime 2 - 3 hour
Switch Type Clicky / Clickie
Switch Location Tail - cap
Lens Coated Glass Lens
Reflector Aluminum Smooth / SMO Reflector
Material Aerospace aluminum alloy
Color Black
Dimensions 6.14” x 1.50” x 1.10” / (15.6 x 3.8 x 2.8_) cm (L x Head Dia.x Body Dia.)
Weight 120g / 4.23oz
Waterproof Yes
Landyard No
Clip Yes
The light is nicely sized and all the checkering helps for a nice grip, even so I would prefer little bit more aggressive checkering, but this is just me…
Here is how the light stacks up to some of my most used lights of the same category:
Fit and finish are just fine, here are few pictures from the thread and the tile-cap, the light came with already applied lubricant on the thread and screwing and un-screwing was just fine:
Contacts are with big, flat surface and provide good contact area. The spring on the rear contact, located in the cap is strong enough to withstand a hit with the flashlight and will not disconnect the connection.
The seal of the light was sort of fine as you can see it works on the bottom on my pool where it stayed for about 10min. :
Unfortunately the seal at the glass did leak and I found small amount of water in the light, but it was working regardless of being wet:
I disassemble the light and blew the moisture away with a can of air. The light was ready to function right after this.
Here is the diode block, removed from the light’s body:
I’m too new to this and cannot tell you anything about it, but it would be nice if this can be replaced with different color temperature unit (IMHO) because this-one is too bluish and it’s less visible. I’d like to see it in let’s say: 5300K spectrum…
I did use the light with one 18650 battery, 3400mAh, Panasonic made, branded for Skilhunt. The light runs little bit hot on max, especially after 30 minutes continuous run.
I did not noticed any drop or deterioration of illumination, I assume it does not go down to less power consumption after certain time as some of the other LED lights in this lumen category.
I was using the Max mode almost every day for minimum of 15-20minutes when walking my dogs and a week later, I still don’t need to charge my battery and without measuring and going trough such small details, I will say that the light is holding up well.
I would still recommend to use a good 18650 type of protected battery.
I only used the light for a week, mostly riding with me in my vehicle but the anodizing shows no wear of any kind so I’m assuming the this finish will hold the test of time and more serious wear.
I have few notes about the way the crown on the tail-switch is designed and about the switch for itself:
The recess as a form is good, unfortunately it’s too shallow and the rubber button is sticking slightly out of the dimensions so if you want to leave the light on its tail, to illuminate the area, it is not possible.
The clicky, as the type that most of the budget Chinese lights are using, works in opposite way the more expensive “tactical” lights have: it needs to be fully depressed and than when you letting it go, it actually turns the light on. Is it a problem ? Not really… Did I mentioned, I was looking at budget light ? It don’t really matter how this switch is working on non-critical use light, as long as it works and this particular one was working every time.
Cycling trough the modes is done by depressing the button half way, little bit confusing in the beginning because of lack of instructions in the box, but there are simple and understandable explanations on the website where one would buy the light, also it is kind of intuitive to try few times and find out how exactly switching modes work.
The clip of the light and the “tactical” holding ring that doesn’t allow the light to turn when left on a flat surface are of good design and quality, they do what they were intended to do, it’s easy to clip the light and take it out of your pocket with one hand, the “tactical” ring have 4 holes if a lanyard is desired but they will allow only a small ring or carabiner to be threaded trough them, which is good option even they don’t provide lanyard with the purchase.
Due to the deep shape of the smooth reflector, the light produces one pronounced round center area of illumination with wide secondary, low illuminated area.
I did test the light up to 60 yards, unfortunately all my night pictures didn’t turn very well and I have to redo them, I’ll update the post later.
It gives good visibility and the center area will cover a normal size person on this distance.
It will illuminate well also a object in about 100 to 130 yards, I’m not sure if it will go all the way up to 200 yards as mentioned in the website. It could probably under certain conditions, I simply didn’t have a useful object on this distance.
I like the light and I’m positive that it worth the $23 they ask for it, I believe it’ll do it for someone that is not too picky and only need a trunk light to use around small jobs.
I do have few little thing that would like to see in a light, based on my experience, if later models have those features I believe they’ll be m ore desirable:
I like to see deeper bezel protecting the tile-cap simply because one can use the light to illuminate a room by leaving the light on, standing on the tail cap, also for protection of the rubber button.
As I mentioned, I would like to see the listed as “White” brightness of the emitter more in the “Day light” spectrum, the color of the current one is too bluish and even the lumen number is high, the visible light isn’t necessary illuminating the target area well, in terms that the bluish light is changing colors and it’s loosing the intensity on longer than 60 to a 100 yards distance…
For any other jobs in up to 60 yards radius, this light works just fine and if the price suits you I would recommend it.
Hope you like my amateur review, I’m open for any opinions and criticism, this is something new to me but I hope with your help to get better!
First post in BLF with a review already.
Welcome to BLF!
Welcome aboard. Give it a little time and you’ll have parts all over the house. Chargers, batteries, assorted O-rings, lenses, odd parts from builds that just didn’t get used and that’s just the start.
Welcome to BLF and nice review.
And what a way to join forum 1st review and post at same time.
Thank you guys, I’m not new to flashlights but I never actually done review… I like to learn more about how to take good shots at night also to find out little bit more what to use to determine the illumination of an object at certain distance, maybe you can give me few pointers. I tried to orient myself in this forum, but there is so much information that I will spend weeks before I get to something… :slight_smile:
Ha ha ha… I’m past this for a long time Sir… I got two big cardboard boxes with parts, O-rings, batteries and flashlights, a table top full of knives, sharpeners, tools and sandpaper, and a spare room in my house full of my guns, parts, mags, ammo, lubricants and so on… :slight_smile: My wife is about to kick me in the garage, to sleep with my bike… I know exactly what you mean…
Looks like you’re going to fit right in.
brother welcome home.
