UniqueFire C8 Red Drop In??
Hi. I’m new to the forum so be gentle. Lol. I have a UniqueFire C8 light. I like the fact that its white orginally but would also like the option to make it red. Does anyone know if and where I can get a red drop in to swap into this light, or is there any other options to make it red? Thanks
Red filter either in flexi sheet form (from photography which doesn’t produce as rich a color) or red glass filter (which the thread probably can’t be directly mounted to the bezel).
You can unscrew the pill out and sent it to vinhnguyen54 who only has the first gen red XP-E, or to nailbender who has red XP-E2 but may or may not do mod jobs. (Both guys are at CPF buy/sell/trade forum.)
You could somehow obtain a XP-E2 and send it to vinhnguyen54.
I myself got a Phlatlight PT-54— from DTR at CPFMarketplace which can be direct-driven to ~10A (the XP-E2 can only do 1.5-2A)— but I’m still waiting for copper springs and improved tailswitchs availability to replace stock springs which will otherwise melt into a pancake.
Alternatively, you can get
SolarForce L2T
SolarForce M3 (which as the same reflector size as the C8)
SolarForce red 5-mode drop-in
The setup is more expensive, but it is pimper.
(The M3 head alone can get you 3 C8’s. The cost of modding and shipping around a red C8 is around the same cost as a M3 host, ironically.)
L2T— $18
M3— $48
SF red drop-in— $12
Shipping— $2
$80
C8— $16
Red XP-E2— $4
LED shipping— $20
Shipping to Vinhnguyen54— $12
Vin mod cost— $25
Shipping back— $3
$80
Pill $4.50 http://www.lck-led.com/flashlight-brass-pill-p-915.html
Emitter $3.00 http://www.lck-led.com/cree-blue-p-1077.html?cPath=37_107_188
Driver $4.20 + $1(remove 6 chips) http://www.mtnelectronics.com/opencart/index.php?route=product/product&path=67&product_id=52
Add a drop of heat-sink compound and make 3-4 solder joints.
Note: There is no absolute standardization between various C8's, so no guarantee that pill will fit yours.
Thank you for the feedback. I did make a filter lens for it using clear plexiglass and some red film used to change headlight colors. It works ok but the result is more pink then red and it does cut down on the brightness a bit. I will look into these options as well. I never realized there was a much involved in these lights.I have much I have to learn before really figuring these things out.
Anywhere that has that driver in stock?
Should be back in stock Monday. Might as well wait, won't get it faster elsewhere I know of. Might want to see if the pill fits first anyway. You can get copper pills but not worth the cost for a red LED.
The pill in the link looks right but have to measure it. Ill check the site Monday
welcome aboard hemimike.
you will meet great people here and soon part with huge amounts of money modding and buying lights. Lots of info here on RED LED hunting lights. I have modded quite of few c8’s with red, green, and white emitters. They make great gun lights.
Kevin
The q-lite 3.04A driver is a little too much for a RED led. Would need to remove a few chips and get it down to around 1-1.25A on an ally star and no more than 1.5A on a copper star.
ooops…edit…i see you said remove 6 chips. that would work.
copper pill is definitely worth it for RED LED’s. especially with a linear driver having to shed so much excess voltage(heat) with the low Vf red emitter.
Thanks kevin, and yes if my handle looks familiar, I’m the same hemimike from bark at the moon. I believe we did business earlier;)
Just buy HS-802, or this drop-in and replace the emiter and driver in your C8 pill
Before I order the pill and omitter, is there anything else I should order? Wire? Adhesive Heatsink Plaster Thermal Conductive Adhesive?
This seller just posted an $8 coupon.
C8 with red LED $26.56-$8.00 coupon + $3.55 shipping+$22.21
http://www.myled.com/p3510-led-flashlight-cree-xpg-red-150lm-1-mode-1-18650-black-led-flashlight-cree-xpg-red-150lm-1-mode-1-18650-black.html
I haven't bought there, but thought you might be interested, shipping's a little high for China.
If you're doing the drop-in mntelectronics has thermal pastes and silicone wire. Do you want permanent (adhesive), or easily moddable (paste)? Silicone wire is additionally very flexible, but I don't expect you need to replace the wires at the current you're using.
Cree does not make the xpg in a red version.
