I received my Uniquefire UF-T20 from the wallbuys Christmas deal the other day. My plan all along was to see what the xp-g2 would do in a decent little aspheric host. So the first thing I did was pull it apart and solder in a 5000k NW xp-g2 from illuminationsupply.
Not only did the tint become what I wanted it too, it became a fair bit throwier over the xml which was my goal. Unfortunately I don’t have any beamshots of the original xm-l (I got too excited and pulled it apart too quick) but I have another UF-T20 on the way so I should be able to compare when it arrives.
Upon testing current draw, it was pulling around 1.95A at the tailcap with the xm-l so I figured it would be perfect for a nicely driven XP-G2. Sure enough, it pulls the same with the xpg2 emitter.
On with the shots.
Shots are taken about 1.5 meters from the wall.
I am comparing to my Solarforce M3 head. I am not familiar with what kind of lux numbers this head puts out but here is a comparison anyways:
Solarforce M3 on highest mode:
UF-T20 on highest mode, full flood:
UF-T20 on highest mode, full zoom:
Side-by-side on high settings:
And now at different iso’s for better comparison:
And just for fun, I glued a GITD o-ring to the little paper insulator ring for a bit of a glow effect when the light was off:
This was one of my favorite mods to date, as this light is just very well made, and now it is a compact little NW tinted zoomable light that can serve many purposes!
EDIT: in the last pic, the emitter looks pretty off-center, but it is simply the camera angle. It is actually very well centered and I will center it perfectly when my xpg die sized centering insulators arrive.
