Update: Thrunite Ti: 3 new Ti's with only one mode! ..Fixed Now
  • This is an update to my other post regarding a new Thrunite Ti I received from the Thrunite store on EBay that came with only one working mode. Since then I received a T10 and T20 that each came with a free Ti. Guess what? You guessed it, all three have only one functioning mode. I can understand getting one fluke light that got by inspection, but all three? Maybe there's a reason they're giving these things away. These were my first ever lights from Thrunite and it doesn't leave a good impression on me. In all fairness I have to admit that the T10 and T20 are very nice little lights and I like them a lot, but these highly talked about Ti's with the highly praised UI appear to be so much junk.
Uhm.. maybe you twisted them too hard and bent the little spring?
I know how they work. I don’t twist lights hard. Right out of the box I dropped in eneloops and gently tightened the head watching for the low mode to engage first. Well, it didn’t happen.
Did you check that the center (U-shaped) spring isn’t contacting the head? That’s how the high is engaged.
My T10 arrived yesterday.Didnt wana play at first.Tried it with diffrent cell brands.It finally decided to work,we shall see if its ok in time .The TN31 & TN30 worked ok,but the threads on them where full of fine swarf.Almost like sand.They all had a burnt odour to them when i opened the cases.I hope my new none buddle batch of TIs are ok when they arrive.
Hope ya get sorted and its an easy fix
DON…
Okay. I got them all working. I used a tweezers and pried the contact upward. This took several attempts, as gentleness did not answer. I had to pry really hard to get that sucker to move. The original one didn’t want to work no matter what I did, so I just said “f**k you” and torked it as hard as I could. Bingo! There was a bit of a grinding feeling and the threads let the head advance a little further and contact was complete. I suppose it was a bur in the thread that wouldn’t let it get where it wanted.
The funny thing is that I thought the lights were only attaining high mode, but it was low mode I was getting. After lifting the contact, high was attainable. Does that make sense? I thought it would be the other way around. Anyway, I thought these Ti’s had pretty crappy intensity for 60 lumens until I hit the real high mode.
All of my Ti’s and T10 worked well the moment I put cells in. T10 has a more durable design as it doesn’t rely on a bent spring or a foam suspenser. T10’s work in 3 modes, twist off/on quickly to change modes. If this doesn’t work or work flickering there may be something on the PCB thats shorting the light or there must be some dirt on the contacts.
Yes, Ti’s have somewhat weak threads. They cross easily so you must watch after them better. I use some dampening Nyogel for better action.
Yes 2, my lights smelled burnt too. Could it be because of the soldering job or the flux they used?
I really was surprised by the T10. I bought it on a lark and it was much smaller than I thought it would be. Runs nice and bright on Eneloop. I got the T10 and a Ti for $20. The same goes for the T20.
This reminded me to test out the Ti bundle I received a few weeks back. Out of the five, one exhibited the same problem where it was stuck on low. I had to use tweezers to fix the issue and now it works well.
I bought 15 Ti's and none of them has problems. They have all two mode.
What is the deal with the 3 lumen sticker on the package ? Are they original much weaker in moonlight mode ?
Firefly mode was originally 0.05 lum or something. I think it’s one of those deals where they asked flashlight enthusiasts what they wanted and of course the answer is as low as possible, but then they found out nobody else buys lights that dim.
To be fair, the high on this light is unregulated and eventually falls to 2lumen of the regular low mode, so maybe 0.5-1 lumen would’ve made more sense, but that’s a lot closer to 2 than 0.0x something.
Where did you get them for 20? :open_mouth:
The eBay thrunite store, on auction. They’ve upped the starting price since though.
I didnt know Cree XPEs could do about 60 lumens on unregaluted 1.5V primaries. ;)
Not regulated for constant power, ie flat output.
