Upgrade cheapie led lights?
Can someone tell me if there is a way to upgrade these cheapie led lights? Most of them are 3x AAA. One has a laser combo that I don’t really need.
Thanks!
John
Oh, I do have some 5630 strip lights. Can I use those? Is there a noob faq for this stuff?
For the most part no. They do sell drop ins and emitters, but they would not work in those lights without some modifications and would not be worth it in the long run. Plus for the price of buying those extra parts you could easily just buy a whole new flashlight. A decent P60 or C-8 type flashlight can be had for around $10-$15 I too have a bunch of lights like those and often think some do have potential for being a good host, but it’s just not practical. -IMO
It would depend on what you wanted to accomplish. Most likely it would cost more than it’s worth but who knows, really. Modding is fun so it’s worth it just to have fun and if it turns out nice it’s an extra bonus. The simplest way would be to see if they will fit lithium batteries like an 18650. If it will fit then you have something to work with and go from there.
Have fun and you win, expect a miracle light to come from one of them and you most likely will be disappointed. Oh and no strip lights.
18sixfifty pretty much sums up my thoughts on that.
I also would only recommend it if your intention is to have fun and maybe get some experience while modding.
My first step would be to disassemble them and take some measurements.
I like the second black light from the right for example. Looks like a nice compact light. So, goes the reflector and electronics out easily? If yes, what’s the inner diameter, what the maximum lenght before the battery compartments starts? (and if not, are you ready to get them out anyway? J) ) If you know that, you can browse sites like fasttech and dx, maybe some common parts will fit?
One could have one or two weekends of fun modding that thing with maybe 5 bucks worth of parts.
If you just want a decent light, better spend you money on something else. :wink:
Thanks for the feedback guys. Too bad there isn’t something cost effective to do with those lights. I have 3x of each type in the pic :slight_smile:
I should have an 18650 by the end of the week (I bought the first light from my headlamp/bike light combo thread). What’s the worst that can happen if it fits in my cheap lights? Melt the internals of the light? I don’t want to ruin my only 18650.
A simple mod you can do if you want something different is to buy a bag of bulk cheap 5mm UV LEDs from eBay and swap the emitters in one of the cheap multi-5mm lights to make a UV light. I did this; and it worked, don't expect great results. The UV output on those cheap LED tends to be pretty weak...
I got one of those multi-emitter lights, a 9 LED one, in order to cannibalize it to get the clicky off of it to use in a Costco light where I had killed the clicky.
Like every other light, once in awhile, I take a look at it, but haven’t been able to figure out how to open up the front end lens. Looking at it from the tail end of the tube, it looks like they have a plastic holder where they stuck the legs of the LEDs through, and then just bent the legs to position them to touch the positive end of the battery holder, so I could at least salvage the LEDs for whatever if I could just open the front end. I don’t know much else to do with it, because the housing (tube) is pretty thin aluminum.
You dont want to mod those lights. They are junk. Each LED is only getting like 20 milliwatts of power, compared to the 1000s of milliwatts that a real light produces.
The driver will be cheap and unable to produce more power. Tailcap will be rated really low, etc.
Its much cheaper to just buy a new light.
+1 it’s easier and cheaper to get a new light … which is brighter
now wheres the fun in all that haters?
As said above, first thing, figure out how to totally disassemble the light down to a bare host, then do some measuring.
Next, go through old lumens, johnnymac’s, infinti’s and matches posts, there are more, but these few stick in my head, your looking to use a tir optic, 20mm star and plumbing parts to make a pill, possibly artic adhesive to hold the pill in the head, then run it on eithee an 18650 or follow old lumens resistance mods on the holder and use 3aaa, if you drive your choice of emitter at 1.4/1.5 amp using a nanjg, you’ll have a nice little custom light that you had the pleasure of building yourself, it’s something I want to do more of in the next few months.
And don’t forget to post about your mod :)!!
I will check out the 18650 and see if I can open any of my cheapies up. I don’t have any quality flashlight carcases to work out of so any upgrades to these will need to be on the simple side. I am still working on figuring out a good headlamp/bike light combo so that takes priority right now.
