sbslider
(sbslider)
17
Jon, I have no experience with integrated charging cells, but if a typical cell charge is closer to 4.10 V on the meter, I would begin to suspect the meter calibration (or lack there of). I know my meter measures about 0.07V higher than a calibrated meter when measuring around 4.2V. It could be that your meter is measuring a bit on the low side, which is why you always measure voltages below 4.2V. Or it could be that your meter is very accurate, and all the cells you bought have the charge cut off set below 4.2V. I hope it is the latter.
