useless for flashlights: MH-B, a new high power Cree led
I thought I'd mention it anyway, the MH-B has a big 5x5mm die, high output, it has the XM-L footprint which could have been interesting, but it needs 37 Volts .
you could make a 12x14500 battery carrier using the Oshpark battery carrier boards. And then a driver...
ok, no, not worth the trouble, useless led!
Is this a new design ? The die looks like a waffle without a dome. I hope Cree will release the XM-L3. :stuck_out_tongue:
The XLamp
These emitters in combination with Taskled HBFlex or hyperboost= win!
No?
I can imagine some cool setups.
Seen the CRI values? 80 CRI minimum all over the place! WOOT!
I guess this is meant for general lighting applications. Funny thing, though. On the Cree product page for this LED, they say it is good for Directional and Semi-Directional lighting. What? Pfft! Is it April First and I missed it?
3 in series is 111 volts and it can tolerate higher temperatures. If the efficiency is good it might wind up in a new cree bulb.
90 CRI typ 2700-3000k, 80 CRI min 3500-6500k.
http://www.cree.com/LED-Components-and-Modules/Products/XLamp/Discrete-Directional/XLamp-MHB
Well, it is supposed to be capable of 830lm at 7W. That would be an efficiency of almost 119 lm/W. But my OCD compels me to tell you that the voltage goes up to 39v by the time it gets to 7W, so 3X would actually give you 117v. And really, I’d be surprised if it couldn’t do much more than its rating. After all, it’s only rated for 175mA! What we need is someone brave enough to buy one and hot rod it to see what it can really do! J)
If I had one I will be happy to test it :-)
You might need three. LEDs and a 120V full wave rectifier :slight_smile:
Use DD with 26s Alkaline batteries :wink:
At only 175ma draw you could use the cheap and nasty ones and still get decent runtime.
Cheers David
I could borrow the 0-230V AC adjustable power supply from work, I made a rectifier (+ fat damping cap) for it so up to 500mA the ripple is not too bad. With this led on a Sinkpad I should be ready to go! The only question is: for whom should I test this led?, certainly not for the average flashlight modder .
Just wire 3 in series directly to an electrical cord and plug it right into the wall socket :P
A nice, clean solution:
Have a look at the XH-G. I thought it was funny that you mentioned the one above. This one caught my eye a couple days ago and I told my bud about it. Not as bright as the one in the OP but usable and pretty cool IMO. :) Would be awesome in a mule light!
These can probably be applied to walls, like ceramic tiles.
It will give “wall of light” and “white wall hunting” a whole new glow.
http://www.cutter.com.au/proddetail.php?prod=cut1886 This caught my attention a week ago. Any BLF experience? (Sorry, tablet too low to post pics)
If you put three of those in series, you’d have 36 volts. But, at 55mAh capacity, what would be their output rate? Certainly it wouldn’t be enough to really push this LED. How about nine of these in a 3S - 3P configuration? According to Engineering Toolbox, if the size measurements from Wikipedia are correct, you’d need a minimum 22.2 mm inside diameter tube to fit three of those pretty snugly inside, and then a length of 85.5 mm to fit three long. Okay, so who’s up for it?
edit: if you wanted 4P x 3S, you’d need an inside diameter of at least 24.87 mm, again, according to Engineering Toolbox. So, with 25mm you’d be good if they were a little more than 10.3 mm diameter. And, then you’d have well over the 175mA rating available to you for testing!
edit again: batteries on ebay
IIIRC, 120VAC peaks at ~160V since 120 is the RMS value of the sine wave (70.71%).
LEDs with a hemispherical dome on top really are not all that good at 'directional or semi-directional' applications. They're best suited for uni-directional or wide-area lighting. We take them and stick 'em in reflectors and just come to expect that how they work is the way they're supposed to... but they were never designed, intentionally, for the things we use them for.
I suspect that if Cree were to do a clean-sheet design specifically to go in a flashlight reflector, it would be flat on top like this one.
Rectifier on AC line gives 168V or so. 117V AC power is 117V RMS. Peak volts is 1.414 times that. Plus you’d have what amounts to 120 Hz PWM…
