Ok, i think i have learned from you all how to measure tailcap amperage and voltage. could you pls explain how, if possible, i can use my DMM to measure the charging amperage on my intellicharger i4? and while we are at it, how about how to measure amperage and voltage on these parallel lights like the srk?
You can measure it with two conductive foils between you put a nonconductivefoil.
Bam now you can put your amp meter on the conductive foils so that the dmm is in series with battery. Voila
Or you could simply put your battery half in and then make contact with the other pole through your dmm.
