Using a UV Light for Curing
Thought I would share here for those that want to cure UV Glue like the stuff they sell on FT. I bought this light from Banggood. It arrived with the exemplary packaging and delivery times that we’ve come to expect from Banggood, got here in 6 weeks in a crushed box and items making a distrubing rattling sound inside. On unpacking I discovered 2 of the 4 UV bulbs had come out of their sockets and were rattling around inside the box cavity, a miracle that they did not break. So maybe you’d have better luck getting the same item from an Ali supplier whom you could ask to remove all the bulbs and bubble pack them before shipping. You could always ask Banggood, like I have with batteries, and they will tell you they’ll do it, and simply ignore you.
Anyway, back to the item. I placed a trit vial into my radio screen and used the 2 minute timer setting, and it was cured in place at the end of 2 minutes. Then I fixed the cracked screen on my camera. I ran 2 cycles with the plastic curing sheet on top first, and then 2 cycles to make sure it was nice and hard, and it looks good. This glue appears to be great for fizing cracked screens on smartphones, cameras, etc. My teenage daughter is also excited to use this thing for what it was originally intended for: drying her nails.
Hey nice idea, thanks for sharing. Next project - fitting Tritium nails to your daughter so you can find her in the dark!
Your link no work by the way.
Oops, I posted the wrong link, I think it should be fixed now, thanks for pointing that out. My daughter just came home, now it’s really going to be put to the test.
Edit: Just an update, I just noticed that Amazon has the same item for the same price, or even less, and you wouldn’t have to wait 6 weeks to get it with all the lamps rattling around inside:
Canadian Link.
US Link
UK Link
I guess I should have done my homework better before I ordered it from Banggood.
So you applied a bit of clue and than pressed a foil on it while curing? Do you have a before and after pictures? Does this clue actually even stick or does it only harden?
I also have a bottle of that glue, I just tested it with a 5mm uv led which I have from another uv glue called bondix or so. But it didn’t work. The test outside was not so impressive too.
Any clue(joke intended) what there is written?
I have a 5W uv lamp anywhere maybe I will test it again.
Unfortunately, I do not have the required lighting equipment and skills to get macro shots good enough to illustrate that procedure for fixing your screen. Also note that camera is not a Touchscreen, not sure how this procedure would affect a touchscreen, but if it’s already broken you probably don’t have a lot to lose by trying. You can still see the spider web of cracks radiating through the screen when it is backlight, but now all the cracks are sealed underneath the coat of UV glue, and if the LCD has not bled out, now it should be prevented ffrom getting further damage as it is sealed.
You don’t use foil, you can use any old screen protector or similar clear non-adhesive plastic sheet, as all you’re doing is using it to squeegy the air bubbles out from underneath just like when you put a new screen protector on a phone. Then when you cure it, the plastic just peels right off as it does not stick (it’s the same procedure with windshield repair).
In previous threads someone usually jumps in and points out they can just cure their glue in the sunlight. That’s true, but I’ve noticed the curing lamps seem not only do it much faster, they seem to cure it much harder in 2 minutes that atmospheric UV seems to do in an hour.
A picture of the repaired display would still be nice, I don’t want to see a professional artwork just a picture of the repaired screen so that I can get a clue how it looks like.
I have nothing to repair I am just curious what I can do with this big bottle of glue…
I would really like to know what is written on the bottle, maybe I should open a fastech ticket they should find someone who speaks Chinese…
The picture that I posted is actually the camera after the repair, I’ll see if I can get a better shot with my higher end Olympus EPL-1.
I didn’t bother with product specific instructions for that glue as all UV Glue is pretty much the same, so I just treated it like the glue that is in the windshield repair kits. You apply it, and then you cure it with a source of UV light, in this case I think these machines are around 365nm, and that seems to work. For fixing a smartphone screen you would put a thin coat on, then squeegy it under your plastic sheet to get all the air bubbles out just the same was as applying a screen protector, then cure it.
Later: I went and got another shot at an angle that shows the screen surface. The camera white balance is off, but the focus is good enough to get an idea. Basically the cracks have disapearred and you can see the fine hairline striations left from the plastic sheet I used. I suspect if you used a better piece of plastic to cure you wouldn’t see them, but in reality when you turn the camera display on I don’t notice them anyway:
Thanks for the pic and further explanations, that looks definitely usable.
I have no clue how to repair a windshield, because here in Germany the repair is made through specialized companies with special equipment and the best it is free(car insurance pays it).
I will try the glue later with a 9*5mm uv flashlight if that doesn’t work I will search the uv bulb…
will it cure under direct sunlight ?
It will cure under sunlight, even under indirect sunlight, as it is the UV that cures it. Where I am right now it is –30C, not very inviting for curing outside! ALso when I cured outside last time, I noticed that glue I was using did not cure as hard as the machine did, perhaps it would have cured better in summer when the UV is stronger.
I had a look at the plastic I used to mask it for curing. It has all those scratches in it which you can see when it cured. If you use real good smooth plastic as your curing mask, it should cure just like glass with no scratches and wrinkles, etc. Like anything new, you get better with practice, so next time I’ll use some better grade clear thick plastic.
Once you have some of that UV Glue, you start to realize you can use it in places you previously would have used epoxy, but as this does not turn yellow, it is better for some projects.
At work they have one of those windsheild kits at the garage, and one of the mechanics told me they paid something like $700.00 for it. I looked at it, all it is is a dremel tool, a glass bit for drilling holes in glass, a UV clamp lamp, some plastic sheets to mask with, a suction syringe, and some UV glue in a small pelican case. Then I watched him fix a windshield and realized anyone who owns a rotary tool could do it. I bought the bit for about $25.00. When I found the glue on FT it was even better. Now I fix all my friends windshields as well as my own, and charge a 6 pack of good beer if they are a good friend, and try for a small bottle of scotch if just an aquaintance. Maybe now I can fix phones as well, however as you can see, perhaps I can only charge one can of cheap beer until I get better.
