I got an interesting idea to use my bike aluminium handlebar as cooling radiator for LED. It is relatively big if you compare it with a regular flashlight body. Handlebar will also transfer some heat to stem which holds it. The driver will be outside, somewhere down on the frame near battery pack. I am planning to push about 10W to LED.
So I needed some kind of mount to attach LED to handlebar, preferably aluminium (good thermal conductivity). Here’s what I come up with:
The mount is 20mm (0.79”) diameter and has threads on the upper part to allow using P60 drop-in reflector. There are 2 holes on the each side of the mount for wiring the LED.
The central wide hole is needed for attaching the mount to the handlebar. I can use metal clamp (not sure how it is called in English, check the picture)
What do you guys think? Do you know if there is any similar project? Maybe you have some design improvements? I have never done any metalworking so I would also appreciate if people with knowledge can check how hard it would be to mill this thing out of aluminium.
Problem is that number of handlebars that are flat like the one from first pic is quite limited, just google bike handlebar and observe images, its like 1 in 20, 25…
Your solution is nice but it will work for not many people. Also, slight curve of the handlebar will send your beam off center noticeably, for me that is quite annoying and only because of this I bought bracket like this one:
I've seen a product for the SolarStorm X2 type lights that looks pretty sweet. I think GarryBunk may have purchased one and may be able to give you input on that product.
Your concept looks pretty nice. It looks like a goo low cost solution. It does seems it would have fairly limited contact area, but maybe it's enough. Making it out of copper (hard to machine) or brass would increase its thermal conductivity.
Hard mounting without cushion will increase the level of vibration the light will experience quite a bit.
Sirius9, I googled like you suggested and here are my top results.
Looks like our taste of handlebars are a bit different and Google does a good job on personalising search results. Or maybe I just don’t understand what you mean, but my view is that this will work for many handlebars. The only difference is that handlebars have different diameters (22.2mm, 23.4mm, etc). For those bicycles which have some angle, it might be possible to change the design a little bit.
ImA4Wheelr, SolarStorm X2 definitevly look cool, but they don’t use a handlebar as a radiator. They have their own. Copper has better thermal conductivity than aluminium but brass has lower:
Copper - 385.0 W/m K
Aluminium - 205.0 W/m K
Brass - 109.0 W/m K
It should be possible to make it rainproof. The driver and the battery are separated, holes can be filled with silicone. Lens can also be siliconed inside reflector.
What is the problem you are trying to solve ? or did you just come up with the …I’ll use the handlebars as a cooler idea and are working backwards ?..
is it a heat issue ? small size ?cheap?
I encourage you to make a prototype from aluminium or even wood and try it on as many handlebars that you can access to, then you will understand what I talked about. It is very rare occasion that handlebar is a straight tube without any bends and diameter changes.
I have OS handlebar and there is maybe 10mm of flat surface from each side of the stem, at best and then shape of the handlebar changes.
I would say that the same situation is with about 5 handlebars from your picture.
O and carbon fiber is not good heat dissipator.
I hope you make prototype soon, eager to see your heat transfer measurements.
Copper – 385.0 W/m K
Aluminium – 205.0 W/m K
Brass – 109.0 W/m K
You're right. I mispoke about brass' thermal conductivity. Most aluminum alloys are supposed to conduct better than most brass alloys. I don't think the typical aluminum alloy we use is as high as quoted above, but it is supposed to be higher than most brasses.
I wasn't talking about the X2 light. I was referring to a mount for "X2" type lights. I think I was thinking of this mount by mtbr member Vancbiker (link in picture).
rmrf, that’s a pretty awesome idea! A little thermal grease between your heatsink and the handlebar would help a bit also, zip ties may be a lot nicer to your handlebar than a hose clamp if ever you need to adjust the angle of the light. Is the light meant for a mountain bike or a road bike? If MTB, the shaking and bumping can cause the head of the light to drop downwards instead of staying horizontal. Maybe a little piece of rubber on handbar,opposite the light would help.
that i have to agree, making a mirror fit will be the biggest challange, but not impossible. one prbly better off using stem, they are more uniform, no bends or diameter changes, then stem will transfer heat to the bars.
When you start looking at details higher end bikes vary widely in construction. Road and mtb bikes are completely different in how the bars and stem come together lots of carbon fiber and wrappings, computers, bends, swoops, etc. the space bare is a nice idea especially as it allows a true center mount. Make a prototype and see what it fits and what it doesn’t. It also has to be sturdy and light or it won’t sell.
Kudos for your tenacity and innovative creativity. :cowboy_hat_face: Considering the relatively limited length heat seems to travel through thin walled aluminum tubing (and far worse through steel), I think you’re still going to need some additional heat sinking to pull this off. Just try ridding with a C8 driven at 3A with a decent (no sag) cell on your handlebars and watch how hot it gets in high mode, even while traveling @20+ MPH.
