Hi, this may seem a silly question to those who know, but since I don’t - it’s not for me!
I recently read (by accident) that someone used 1x 18650 in a 3x 18650 flashlight - I have a Courui D01 and it does indeed work with 1, 2 or 3 batteries - I just wanted to check if it’s ok to do that?
I am guessing all that will happen is it will last less time before recharging? H)
Also the batteries I am referring to are Authentic EVVA 18650 3.7V “3500mah” Rechargeable Li-ion Batteries (2-Pack) from Fasttech - they are supposed to be 10a drain, protected NCR18650GA but if you read the discussions going on there below, people are saying they are in fact not high drain and re wrapped NCR18650B with a protection circuit. Any of you guys shed any light on this?
The batteries will be fine; you’ll mainly just get less runtime, and perhaps a bit less max output. In the Courui the batteries are in parallel so a single cell provides similar voltage as 3.
Though I would keep the 3 matched cells together, and not use them for any other purpose except for a 3 cell flashlight.
Good Day G0OSE,
The problem is that you will be drawing the same current/load from less batteries => Greater load/current per battery, which MAY lead to battery damage & shorter working life.
Best Regards,
George
If you use protected batteries, then the current for a single cell might be too much and trip the protection and you won’t be able to use it. Other than that and shorter runtimes there is no problem.
Thanks guys for your answers, has reassured me and I feel safer using just the 2 batteries, the beast is also less heavy!
