I’ve been thinking about getting a SENS AA to use in a Nitecore HB02 headband. Has anybody tried a SENS light as a headlamp? It seems like it would be a great UI for headlamp use for night hiking or trails. My concerns are that the ramping adjusts the light output appropriately and that it’s not too dim when you are looking down right in front of your feet. Anybody with experience?
I’ll just make a quick reply:
- beam pattern is great for trails/finding your footing and the high output is enough to be good for this purpose even at a running pace.
- you don’t have to run it in the auto level mode, direct mode access is one of the things I love about the sens interface (eliminates toggling in a multi mode twisty).
The lowest setting isn’t enough in mixed terrain, wet ground, twilight conditions or when you’re moving fast (trail running). However for many tasks the lower levels are handy and the driver is known to regulate very well and is current controlled so there’s no annoying pwm.
I doubt you’ll be disappointed with the sens if you get it, the ergonomics are good and it has a great ui for a twisty. Has the caveat of denting the negative end of batteries, but as a whole it’s a fantastic pocket light.
You connected to bluetooth audio devices and wireless display in windows 10,here the most simple method to connected wireless audio connection with your pc fix connections bluetooth audio devices wireless displays it is very simple plan to connected audio device,thank this info.
