There is something that could be really useful for my project, and I could really find something about that. Maybe I have not the right keywords…
Well, if you look closely at mcpcbs designed to run XHP50 or XHP70 at 12V, you can see that the led seems to be made of 2 independent parts, that you can actually run in // or series.
In some cases (like 12V/6V compatible mcbcps), you have to use jumpers, that can be used to put an additional wire between those 2 equivalent leds… Which means you could really use the XHP as 2 leds wired in series, and lit only one of them.
Is it actually possible, and has somebody here already done it ?
I thought that lighting only half of it could create a weird electrical path, or thermal stress inside de led body, but this souldn’t be so bad, I guess… As long as the “middle” pas is not in contact with the mcpcb “ground”, it should be ok.
It is getting late and I must be writing like a 5 years old, I hope it is still understandable…
Yes, it can, it’s not going to get damaged. You can get a 3V XHP50.2 or XHP50.3 and use the four dies independently without any problem.
I see an application for it, for car headlights. The shape you get from using only half of the LED is very similar to the profile of a halogen bulb filament. There’s LEDs made for this on the market, but you can get more options of CCT and CRI with the XHP50 and XHP70, and its intensity is quite high, so technically you can make some kind of bulb with the LEDs half lit inside a headlight assembly while keeping the stock beam profile. In reality though it might not work out as smoothly as it looks like it can.
With the 3V configuration, the central pad is the common - and the 4 forners are the + ? Have you ever seen mcpbs with separate pins for each sub-led ? That looks pretty specific… Even the mcpcbs made for 12v, of which the central pad can be wired too, are quite rare.
For now, the independent dies will not be useful for me, but the 12V separation could very well.
In fact it could help with bike standlight, suppressing the need of a schottky somewhere in the circuit, and thus improving efficiency.
Adaptive headlights work like this. Or at least they used to. They’d have multichip LEDs but with the chips in a row, not in a square, but same idea. Like 3-5 chips in a line, and they’d have like 5 of those, so like 25 chips that’s can be individually controlled. And maybe they’d have 2 or 3 rows of those. But nowadays the high end ones have multi-pixel LEDs, and they’re like 25,000 individual chips or pixels or w/e you call them in each LED. Idk if that’s just a tv screen at that point though
That’s what I feared, so you confirm that the XHP50 exists in 2 different versions : 3V and 6/12V ?
I found several places to buy the sinkpad mcpcb, that allows 6-12V use. It’s biggest interest being that the traces allow to command the central pad’s voltage, while it is usually hidden beneath the once it is soldered.
I only found it on cutter and mtn, that have unreallistic shipping fees for europe…
Anybody knows where I could find similar mcpcbs, please ?
I could use a standard 12V dtp mcpcb and use its core as an electrode, but that’s not ideal…
Actually, this mcpcb could help for what I want.
An additional wire going from the far right and far left pins of the mcpcb would make the XHP 12v, and allow to extract the “middle” voltage, isn’t it ?
I’m not understanding what you mean by “extract the middle voltage”, are you trying to run the XHP at 12V while keeping the thermal pad with zero electrical potential? If yes, this will work. Also, if you get a 6V PCB, you can cut the top traces to divide the PCB in half, this way you can do this exact same thing using a cheap ol’ standard 6V MCPCB.
Yes, I want the mcpcb core to be fully electrically isolated from the rest.
With a 12V config, in order to run them in series, but still with the possibility to “control” the middle voltage, to run only 2/4 dies if needed.
Your proposition matches all those requirements ! Thank you very much !
