Hello,
Today I received from Gearbest, gratis, these two supposedly ‘identical’ lights, the black Utorch XPL V6 ($8.27, product link ) and the pale blue Convoy S2+ ($11.99, flash sale price, product link ), both are direct dealer, non-affiliate links)
As we all know by now, the Utorch brand is a GB in-house brand (like the Zanflare), and is subcontracted to Convoy.
Is the $3.72 price difference justified? Take a look below:
They are the same in this first set of photos:
Side-by-side, without their tailcaps:
The BLF A6 thrown into the mix for perspective:
The tail-caps:
The tail-ends of the body tube:
The tail-caps:
…and at this point they differ in their front-ends: (Utorch, left)
Same orange peel reflectors: Convoy (top) XML2-U2 ; Utorch-XPL V6:
Brand-new Sanyo NCR18650-GA are being charged at the moment for some beam shots.
Edit: Comparative beamshots in post # 8.
Thanks Tatasal.
This is what I’ve been waiting to see. Time to order a bunch of them.
I see. subcontracted to Convoy, no wonder it looks exactly like the Convoy S2+…
a lot of flashlights look very similar to the Convoy S2+ too, notably the Eagle Eye X2R…
The LED and driver choice for the UTorch is different than from the S2+ though (XPL-HD and 5-modes-only driver)…
I’m quite surprised of their high value-for-money factor, inexpensive, not cheap kind of lights.
The Utorch for $ 8.27 and the Convoy for $ 11.99 currently? You’ve got to be kidding!
Can you comment about the quality of the Utorch compare to Convoy S2+ (thread, machining, build quality, tint,etc). If you have to choose, which one would you rather have ? The Utorch quite intrigue me but i would spend a bit more if the S2+ is better in term of quality.
Nice ! I intented to do something like that but was too lazy ;-) Thanks for doing it and i hope you will forgive my "piggy-backing"
The two heads look very similar from the outside but when dismantled one can see some differences (beside the leds and associated gaskets) :
Pills differences:
  • Utorch pill length 11.5mm (left), S2+ pill length 13mm (right)
  • Flat front end for the S2+
Reflector differences :
  • Utorch reflector length 12.0mm (left), S2+ reflector length 11.6mm (right)
  • Utorch led hole 6.5mm, S2+ led hole 7.2mm
One more minor difference : Front O-ring is black for Utorch and Glow-green for S2+
About Utorch quality :
  • This is very subjective and i don't have any left with the original Black anodization but i didn't like it like very much ... up to the point that i baked one and sanded the other for a "worn tool" finish.
  • An other thing is that one had very gritty threads (ok after several screw_unscrew with added silicon grease)
  • The weakest point of the Utorch imho is the driver (no way to remove blinkies)
Thanks for the comparisons! I won’t probably get the Utorch, but is nice to see whats beyond the first look!
Looks like the Utorch has the tighter hotspot and more neutral tint:
Control shot:
Convoy XML2-U2 6500k:
Utorch XPL, unknown led tint (looks more neutral on white wall, better color rendition on green leaves:
Convoy on the left:
If you look closely at my photos, other than the driver in the head, you will notice it’s a toss-up between the two, as virtually they are twins, regardless of the $3+ price difference.
Hum, that “rendition” don’t have something to do with some “yellowish” tint shift?
The XPL-HD seems to be Neutral White, but those Leds normally produce some shift even under an Orange Peel reflector (at least against a white wall).
If that is the case, the incidence of the corona on the green leaves makes them more “rendered” not so “white” !
