Hi BLF,
I am with DXZ Lighting, a manufacturer in Guangdong, China. We build lighting for vehicles and job sites rather than for handheld use, so let me say the required thing plainly: I am a commercial seller, and this is our vendor thread. Everything below is our own product line. Please read it as a vendor post, not as a review.
What we make:
Auxiliary driving lights and off-road light bars, single-row and double-row, in spot, flood and combination beam patterns
- Work lights and flood lights for trucks, trailers, tractors and earthmoving machines
- Warning and signalling lamps: beacons, strobes, and marker or clearance lamps
- Wiring to suit the load rather than the catalogue photo: harnesses, relay kits, switches and connectors
What we can put in writing, because it is usually the part that goes missing:
Emitter bin and CCT, plus what the measured tint actually looks like rather than the nominal Kelvin
- Optical design: reflector or TIR, the real beam angle, and where the hot spot falls
- Driver topology: buck or linear, and the input voltage range over which regulation actually holds
- Thermal path: the mass behind the emitter and the derating curve, not only a peak figure
- Ingress rating and the test conditions behind it
I know the reputation this category has. Numbers that do not survive a bench test, and tint that turns blue the moment you look at it. If you want to compare any published figure of ours against your own measurements, ask and I will post the test conditions with it.
Website: https://dxzchina.com
I am not going to flood the forum with threads. If you have a question about a specific application, whether that is beam pattern for a particular vehicle, amp draw on a harness you already have, or what actually changes between two lights carrying the same claimed wattage, I will answer it here.
DXZ Lighting
