Very basic camping light DIY questions
Hi, I’m very new to this flashlight game although iv been using knockoff “cree” flashlights for a while and have dabbled in modifying a few P60 lights for scuba diving and UV coral photography as well as building reef aquarium lighting (following someone else instructions!) Id consider my electronics experience beginner to intermediate but I need to double check iv got things right for my current project.
I’m currently building a light for camping/fishing which will be mounted on a flat aluminium heatsink and powered by a single or possibly double (in parallel) NCR18650Bs with a protection PCB giving me a max output of 4.2v.
Ideally I want a separate red light and white light. Iv got a few 3w bridgelux red and daylight LEDs left over from old aquarium lighting projects but the drivers I have are incompatible with my project as they were powered from 230v AC.
Bridgelux specs are as follows:
Bright Red 630nm: Forward Voltage: 2.2V-2.7V Forward Current: 600-800mA Output: 85 lumens
6500k Daylight White: Forward Voltage: 3.2V-3.6V Forward Current: 600-750mA Output: 240 lumens
Am I right in thinking two AMC7135 chips per LED will be fine to drive them? I’m not really looking for any fancy features just simple on and off via a toggle switch.
Iv also been playing around with some cheap eBay 3v 3w 60x8mm COB chips. I haven’t actually powered them up yet to test them but also wondered if anyone has had any experience with these?
Data seems to be limited and the sellers don’t seem to have a whole lot of info when I ask them. The most I seem to have been able to get is this:
White Forward voltage: 3-4v Max Current 1000ma
Red 2-2.6v Max current 800ma
Am I right in thinking that two AMC7135 chips would be fine to drive these as well?
The AMC chip is not going to like bucking off 2V. You should run a buck driver on the red not a linear driver IMO.
Any tips on what driver to go for or would it be sensible to step down the voltage then run it through the linear driver? A lot of the drivers I can find online have too many functions that I dont need.
Would the AMS1117 be suitable?
Suggestion: avoid cool white for a camping light. You don’t want to have the feeling that you are in an hospital waiting room. Go for a 3000-4000k for a warm mood in the woods.
Exactly. Much more thoughtful to your camp neighbors as well.
