Back in Feb I ordered a Manker U11 on a whim, as someone said in a thread on here how good the UI was, allowing you to do certain things. At the time, the info online was a little limited to how the UI worked. So I ordered before fully researching the light.
It turned up yesterday (brown box from FastTech, which I know there have been some issues with).
And what a disappointment it is.
Don’t get me wrong, I like the physical light, the output, the beam profile. Even the tint is perfectly liveable as it’s not a nasty CW. Build quality looks good too.
But the UI???
WTF!!!
How can a designer get it so wrong and miss by such a margin.
I’m suspect there will be those that don’t agree with me, although I’m not sure they would be able to justify it, not if you really think about how it works.
Requirements on a light like this are pretty simple:
-activate to moonlight from off
-activate turbo from off
These probably the modes that will suit most people and are the modes you don’t want to faff getting too. Most other modes you’d probably be more content to spend a little more time getting too.
The U11?? Nope, completely fails at this.
For those who don’t know.
Quick click from off gives you moon.
Long click from off gives you last used output.
Double click from off gives you strobe.
Now some of you might be thinking a long click and memory will solve this. But it doesn’t. As it means you have to remember what mode you last used, which is a PITA. So chances are when you do a long click, you are not really getting what you are after, so still have to click through the modes.
Here lies another problem. If you double click while on you also get strobe. So this means you cannot cycle through the outputs quickly.
EXAMPLE:
You activate moonlight, and step up to Low. You turn it off.
You next sometime later want turbo. You long click, but get low, you slowly cycle through the modes. If you are lucky and count correctly, you’ll get turbo, if you are unlucky you’ll get strobe. Or if you miscount you’ll get moonlight and need to start over.
A terribly annoying and awful setup.
With an electronic switch, you can quick click, long click and double click. Surely 3 ways to activate the light should at least allow you to start at either end of the output modes That’s just obvious.
As a more advanced tweak, maybe it would be nice if you start in Moon that the next mode is brighter. But if you start in Turbo, the next mode is High. There are almost no occasions you’d want to go Turbo to Moon as a use case…
But you might want to step it down a tad, without having to cycle through all the modes.
I truly do not understand the premiss with which strobe is given on lights like this. I know for those who want it, it needs to be accessible. But there must be a better way.
Logically, the number of people X the number of occasions you’d want Moon or Turbo has to much greater than the 0.0001% of people who 0.00000000001% of the time need to use strobe? It’s a specialised feature forced on the masses as the sacrifice of common sense and a better overall product.
The thing is, the U11 actually has two mode groups…. essentially too different sets of modes. So why the hell could one of these groups not bury the strobe modes???
The “pro” group has the Zebralight programmable outputs for the different outputs. Which I’m sure some will claim as invaluable. But the reality is, they serve no practical function what so ever. And the defaults for the “General” mode seem to be as good as you can get with the choices anyhow.
Two more stupid design elements.
-Burst mode. This tries to maintain a stable constant output of turbo mode (what ever you’ve programmed it to be, there are 3 turbo settings). Sounds like a useful feature, until you realise that it’s a hidden mode on the pro group only.
So assuming you are in pro mode, you first need to double click and get strobe and get dazzled, click again for breath mode and be in darkness, click again for SOS, click again for beacon and click again to get to the constant Turbo mode….
That’s 6 clicks…… of careful timing and a variety of dazzling modes before hand. What a F*cking stupid setup.
-Breath flash. This is actually a really cool mode, it makes the side switch gently flash, so you can find the light in the dark. But to get to this mode you have to activate strobe first…. WTF :person_facepalming:
And when in this mode it’s challenging to get to any other sane mode. I suspect most of the time you’d want moonlight, or at least a quickish way to turbo….
Such a shame.
A potentially great light, blighted by short sightedness on a badly setup user interface.
