Vf Group for XP-G2s
So I'm trying to order XP-G2s. The tech guy asks me...
Which forward voltage are you looking for, we stock the F, G, and H groups... 2.75V-3V, 3V-3.25V, and 3.25V-3.5V respectively.
bottom of page 8 of the Binning and Labelling Datasheet shows the actual voltage ranges for the specific groups.
I use a KD 8x7135 V2 or Nanjg 105C Drivers. I think I know which group but I'm not sure.
The lower Vf, the better regulation.
He mentioned "As far as which one to get would depend on the rest of your circuit." so I guess that those drivers will work fine with either F (2.75-3V), G (3-3.25V), and H (3.25-3.5V) groups.
I just didn't know what Vf the KD 8x7135 V2 driver was putting out. I don't know if it varies with the particular LED or what.
The KD 8x7135 (and any linear driver for that matter) will put out whatever Vf the LED needs. That said, a linear driver can not put out a higher voltage than it takes in from the battery. For this reason, the lowest Vf emitter is the best choice. The KD driver will supply it with the voltage it needs for longer.
get the F Group.
PPtk
Then yes of course I want the Vf Group "F" (2.75-3V). I don't want this LED cutting short. I want it to act like regular lights and some of these may go in dive lights and I want long run times.
Thanks all.
Not sure if the vf grouping is used on xpg2. The datasheet says ‘red, amber and high efficiency white’
Woody
yeah I'm talking about regular XLamp LEDs.
Woody you can't put quote marks and not quote the text. it says...
"Amber, red-orange, red and High-Efficiency White XLamp LEDs"
Here's the list from digikey. the F,H,G groups are seen under Manufacture Part #
Hey maybe Id make a good politician with my ability to invent quotes and fabricate data. Sorry, it was written in a hurry and my old memory isnt as sharp as it used to be!
Im still not convinced that that xpg2 is a High Efficiency white led though….
Woody
No, you got it wrong! These are order codes, F/G/H are luminous flux codes and 51 is chromacity code (51 - 6200K, 53 - 6000k etc). Go to page 35 of the B&D datasheet from your first post.
LOL. Ok well that's why I'm here asking the questions. These order codes kick my butt. Good save phantom because I probably wouldn't of liked what I got.
I also remember telling him I wanted NW tint.
I'd like to get that higher CRI (75) that I see on pg. 35.
