So, this is my first attempt, but now my broken Acebeam T20 works again. The gain in output wasn’t much really, but I’ll give my before and after figures. Before: 1383 lumens; 264,580cd. After: 1445; 267,560. The new emitter was this one from Mtn. Electronics.
Yeah I was sure I didn’t see one on it either. I just looked at the boards closely, noting the traces, polarity, and electrical flow on the PCB and it worked out for me. I think I’ve heard most emitters do have some sort of external markings… I guess except for the XPL HI. But that picture helps for those who just get the bare emitter.
Thanks! I spend a lot of time making cuts here and there trying to make them fast paced and watchable.
A few people were chapped about by that Noctigon video. Sorry! I won’t be dropping this light again. Those centering rings are basically razor blades for those XPL HI emitters. I won’t be doing that again.
I’m happy you’ve been successful with the reflow. I’d like to point out somethings. 1) the lighter’s yellow flame would leave soot on the bottom of your stars. Did you wipe it off before putting it back in the light? 2) did you reapply thermal grease between star and flashlight? It’s not a necessity but reduces the possibility of air gaps underneath your star. 3) Personally, i would have applied a little less solder to the acebeam’s star but it’s unlikely to make a difference
4) if you drop a light and it fails, it’s not your fault, it’s the fault of the manufacturer. They need to change something.
1)I actually removed some of the solder. I had to do a bit of creative editing, and I didn’t show that part. I probably still did a bit too much though, but it did lay as flat as the other one. 2)Also I wiped the little bit of soot from underneath the star. I did actually buy a butane torch, but it looks kid of crappy and there wouldn’t have been enough room to hold the long, pencil sized one I purchased. 3)I did not apply more, there was a bit left on the emitter shelf inside the light, so I left it.
4) I did drop it from twice the height the manufacturer recommended. But, I personally think it should have a square spacer- but those XPL HI’s have nothing to protect them. I don’t think it should have killed it either… but hey- flashlight science.
Also thanks for the advice on this. It didn’t go too bad!
3 ) I’ll edit my opinion and suggest that you remove the old and put a new bit of thermal grease if you have I watched a video tonight and the guy (old electrical engineer) said that a drop in the middle of the LED (he was fixing a 50W LED to something) would spread out evenly and eliminate air pockets compared to what he used to do ie, put multiple bits of thermal grease before pressing down the star. Air is baaaad man! Others will chime in and agree or disagree.
To be honest I had none on hand… This morning though I have ordered some attic silver ceramique 2. All I had was the thermal glue, which I do not want to use.
