Want to build solarforce L2T that pulls 4.5A+ -- Any Advice?
My favorite woods light is starting to show its age, so I am considering building a new one.
The original:
Solarforce L2T w/ clip
Carclo 10048 26.5 mm TIR optic
NANJG 8x7135 driver, +4 7135 chips
Neutral XML2 on copper sinkpad
All mounted on a huge copper slug
McClicky in the tailcap
The original light would only pull 3.5A on a fresh charge (samsung 4.35v 18650). I also was unlucky enough to build the whole light before I found out my driver was faulty with the strange flickering problem.
The replacement (in planning):
OSH BLF17DD driver
Cool White (3C) XPL on copper noctigon
All mounted on huge copper slug
Here are my questions:
1) Is the VF of XPL LED lower than XML2? I’m really wanting to pull 4.5A with this light.
2) How much better is the voltage drop of the BLF17DD than the NANJG with 12x 7135 chips? Would prefer to use a standard 4.2v cell and still pull 4.5 amps…
3) Does anyone have any other thoughts or suggestions?
Thanks!
Go to MTNElectonics P-60 page get a bare P-60 then add the emitter and driver. Easiest driver would be the QLITE have Richard add 8 of the 7135 chips and you will get 4.5 amps. More than that is pushing your luck due to heat problems inherent to the P-60 design. I have an XML in a P-60 running at 4.5amps and it gets pretty warm. I can’t set it down or it’ll fry the LED. Some times I set it lens up in a tall glass of water to get light in ceiling bounce if camping or power is out. Ask Richard, he might put it together for you. I think you might have troubles if you run it with the FET driver, it’s worth a try.
You will need to solder copper braid or extra wire to the springs to carry the current and a switch from Tofty.
Are you set on keeping the L2T? If you do, you really only have to swap the driver and emitter, but I think a Convoy M2 host would do much better thermally.
I had it in my head the the XP-L actually had a higher Vf, but now I can’t find where I read that, so I could be wrong.
edit: according to Cree’s site the XP-L has a very slightly higher Vf
Thanks everyone for the input.
I am not worried about heat. I will use a big copper slug to transfer heat to the body of the light, and I will never use the light other than in my hand so I can monitor the heat buildup.
I do like the L2T because of its feel. For this particular build, I’m going to stick with it.
My biggest concern is getting enough voltage for the LED to draw 4.5 amps or more. I had heard the XPL had a slightly higher forward voltage as well, which will work against me. Does anyone know if the BLF17DD has less resistance than the NANJG?
It’s not just the XP-L which has a high Vf, the word is that all the new batches with that die (eg both XP-L and XM-L2) feature a higher Vf.
IMO you may be forced to use a DD driver, period. The BLF-DD and Axx-DD drivers have significantly less resistance than the Nanjg-105c / D. You must braid/bypass both springs, although ideally you’d eliminate the driver spring.
Consider switching to a triple?
Thanks wight for weighing in… For this build I am wanting to stick to the Carclo 10048 optic. This lens combined with the solarforce L2T and the CLIP is one of my favorite combinations. I am looking forward to rebuilding it with more up-to-date parts.
I appreciate everyone’s input. Let me know if there are any other ideas.
PS: scottyhazard - thanks for the reference to Tofty’s switch, I had not seen that before.
