Yeah, it has enough potential to turn it into a decent light.
If you have a 20mm copper dtp LED board that fits snugly in the pill either with or without a bead of JB Weld, it should be safe to run up to 10 Watts i.m.o.
Or just run 6 Watts or so with a Nichia 219B or C you may already have in stock.
Stick in a nanjg 105 with 5 or 6 × 7135 driver you probably still have in the spare parts box and the pill is good to go.
The tailswitch may have to be replaced.
Those ultra cheap tail switches can be really bad.
But a press fit switch assembly usually is good enough if it fits snugly enough.
But the plastic reflector is probably good enough for the job and it seems to already have a glass lens.
