sorry, my english is a bit weak, but I am working hard on a comprehensible diction
I use a IR Flashlight for lighten my Night Vision. The Torch have a 17mm reverse Clickie Switch in the Tailcap, but unfortunately the Switch clicks fairly loud and is hearable in a good distance in quiet environments.
Is there any good-Quality and silent Switch like the Omten 1217? Max. Dimensions 17,8mm x 12mm, reverse or forward Click doesnât matter.
How about one of these? you can buy in different types/sizes/ratings/illuminated, latching, momentary. I would imagine they are quiet - sound absorbed by the steel
Depending on your application, a simple and/or temporary solution could be to use the tailcap as a twist-on switch (assuming it has mechanical lockout)
I would suggest looking into a tape/pressure switch if momentary on is all thatâs needed.
Do you have a picture or model of the torch/flashlight you are attempting to modify?
Not to be Debbie Downer, but keep in mind that the âsnap actionâ is what helps preserve the switch and extend its life, by minimising the make/break time of the switch where it suffers most from arcing. The more the switch lingers with the contacts in close proximity, the more pitting, etc., it suffers, and the more its resistance goes up. So a good solid snap, hammering one contact into the other, then similarly yanking it off, extends switch life.
Some relays actually have separate ratings as to how much current the contacts can carry, and how much they can switch.
So⌠just something to keep in mind.
If itâs a C8-type light, use a pressure-switch. Or someone here was selling FET-based tailswitches, but dunno how quite the switch itself might be.
My Zebralight Headlamp has a very silent Switch in the head, I hope I find a similar one for my IR Flashlight.
My actual Workarround is to twist the Tailcap to switch on and off. Not perfect, but it works.
An âe-switchâ can potentially be silent. In principal, this is due to the same reasons Lightbringer mentioned with arcing and contact acceleration/area/presssure. Your ZL uses an eswitch, which is just a very low current signal to the driver to turn on other solid state components that handle the full electrical load. There are designs by members here that likely can be adapted to your light that utilize an e-switch+FET+power source in place of the omten âclickyâ switch.
If you post a picture or reference to your IR flashlight, someone can likely help you find a solution
*also, do you need a latching switch, or is momentary only sufficient?
Good idea, and i donât see why it shouldnât work.
From memory i recall that 7135s have a limit as to how low you can PWM them before they stop responding so itâs possible that on the lowest PWM setting the 7135s wonât fire at all. Somebody else or the search will have to provide more specifics though
