Got mine.
Red Noctigon board
Opened up, removed the black parabolic thing, wiped some excess thermal gunk off the back side.
Lots of gunk under the board, oozing up around the edges everywhere. Will come back to that to clean it up.
Taped the led solder points, put in the 18650 adapter, tried with a low-powered 18650 protected cell with a tiny plus bump.
Works OK.
Light doesn’t seem to get hot; wondering if there’s too much thermal gunk (probably so)
Sometimes the “short click” has to be very short, otherwise it goes into reverse — comes on low, bump the button and it’s in turbo.
When it’s doing that, the short click is a tiny fraction of a second, barely touching the button, to get it advancing normally through brightness levels.
Other times the short click is the usual slightly longer time — haven’t found a pattern on that yet. It’s tolerable.
Lens looks like the same size as the lens in the “Sharp Eagle 3-emitter ‘nut’ light”
One tip: after taking the bezel and lens off,
To avoid crunching the lens, make sure the “zoom” is partly out before threading the bezel-and-lens back onto the flashlight.
Otherwise it gets tight and feels like it might crunch the lens before tightening past the O-ring.
Your welcome Tom, just trying to bring a little levity and beauty to a serious thread! It’s a Tacticool ring off one of my JAX X6 tubes that I replaced with a Convoy L2 2X 26650 block tube (either will work). It self center’s to the body and can be rotated to match the cap cut outs. It’s retained by the cap, but wouldn’t make contact, so a made a ring out of solid copper wire to fit inside the cap, soldered and flattened (1.3mm thick) till it made contact, added a KAN9 FW click switch and braid, and black boot complete the tacticool function/look. Besides don’t need no lighted tail cap giving away my position! (wouldn’t be tacticool at all!! )
Has anyone done a tailcap measurement with a COMETA…. just as it came from the box ??
If so and you don’t mind sharing…. what were the results?? What should the results be???
Thanks in advance….
