Warrior 2 swap emitter help
I was wanting to switch my olight warrior 2 To a warmer emitter around 3000 to 4000 K I thought it was an XHP35 HI but it looks different… anyone know what this is and what I could swap it to with a link maybe mtn electronics?
Thanks
This is the full-size Warrior, and not the Warrior Mini 2, correct? The Warrior 3 uses the SFT70 (a 5050 6V emitter) so that is likely what you have here. In that case, the XHP50.3 HI would be your best bet at the moment, though there are apparently some Getian emitters that may be available in the near future.
The phosphor appears to extend all the way to the edges of the emitter surface which would imply a HD XHP35.2 or .3, whereas the XHP35.# HI edges are clear of phosphor.
Is it possible Olight dedomed the XHP35.# for this light? A voltage (6V or 12V) would tell.
MtnElec doesn’t currently stock any lower K temp XHP35 but Mouser does.
M2R Pro?
