In the past we used charger and rechargable batteries. It's a big trouble when travelling outside. But now, water activated battery solve the problem!
Just $2.98 + free shipping!!
Definition from Wikipedia:
A water-activated battery is a disposable reserve battery that does not contain an electrolyte and hence produces no voltage until it is soaked in water for several minutes.
Steps:
Unscrew the bottom cap with the supplied tool or a coin
Submerge battery in bottled or tap water for 5-10min
Take battery out of the water and dry battery completely
Screw the cap lightly back on the battery
Battery is now read of use.
So what is the Mah rating and discharge capacity?
Battery: me last you longtime
slightly cheaper here with two.
2PCS 1000mAh Positive Energy 1.5V AA Water Activation Eco-Battery Rechargeable Battery
Product Features:
Water activated, just need ordinary water to start working
Do not start to produce power until water is added, aquacell batteries have an infinite shelf life
Aquacell uses recycled plastic instead of steel and replaces most other heavy metals
Eco and environmental friendly
Battery type: AA
Power: 1.5V
Net weight: 30 g / 1.06 oz
Size: 50 x 14 x 14 mm / 1.97 x 0.55 x 0.55 inch
1.5v rechargable :~ au$4 for two, I can buy 1.2v 1000mah rechargable from my local hardware store $8 for 4, so where is the bargain super low price, also where do I buy a 1.5v charger, dont tell me TinyDeal :bigsmile:
I think I will save some water and give it a miss.
Cheers David
A battery with water as its power?
I will try to buy it and start drinking beer from now on J)
These are like the NOPOPO brand from Japan. Can you use urine on these new ones too?
These are quite interesting as technology. But I do not understand the talk about rechargeable batteries here. These can not replace them, or even alkalines.
What I collected from wikipedia
CONS:
- Less than ½ of the capacity of alkaline, or NiMH
- Not suitable for high drain applications
- Short life after activated (how long, does anyone know?)
- Known to deform and cause damage to devices
- disposable, 1-time use
- Needs water and 5-10 minutes to activate
- Price
PROS:
- “Infinite” shelf life before activation
- More environmental friendly materials than in alkaline battery
There has also been a thread about these before. Even tho these do not seem very practical, I might get a few just out of the curiosity ![]()
It states at the link (even in the link) in the op to TinyDeal marked as ’$2.98 + free shipping’ that they are rechargable :bigsmile:
www.tinydeal.com/2pcs-1000mah-15v-aa-water-px2hpr1-activation-rechargeable-battery-px2hy27-p-136705.html
Cheers david
Oh lol. I hope they just misunderstood it, and didn’t try to mislead customers. Some might actually believe that it uses water as fuel, and that you could just add more water to use it again ![]()
So if i understand correctly one buys these batteries, adds water to activate them, use them in a low drain device (not a flashlight), it has half the capacity of an alkaline or NiMH, and when it runs out of power i throw it away and buy another one (and no charger is used in this sequence of events).
It sounds a lot like an alkaline battery only less capacity and more expensive
just a gimmick for suckers.
