Weatherproof TrustFire X8 Cree XM-L T6 LED Flashlight with 5 Lighting Modes
Details:
With the lamp cup from XM-L T6 and the ultra-deep mirror reflector, this flashlight creates strong, concentrated light. Its light, anodized aluminum design protects it from high temperatures and pressure. The thermal sink is built into the body cover, which greatly helps to dissipate heat.
The flashlight’s intelligent digital circuit control technology allows for five different lighting modes. They are: High, Mid, Low, Fast Strobe, and SOS Mode. The amount of light given off varies in each mode. Users can easily change modes to match different situations. The flashlight’s weatherproof, large-diameter, O-ring seal allows users to safely use it in a variety of environments, even in severe or rainy weather. This makes it perfect for activities such as camping or hiking. A strap is included with the flashlight, making it even more convenient to carry and use.
The Cree XM-L T6 LED bulbs included with the flashlight have a lifespan of up to 100,000 hours and the light emitted can go up to 1000 lumens. The flashlight can be used continuously for about 1-1.5 hours with the 2*186650 attached. This flashlight is perfect for outdoor activities.
Highlights:
- Designed to withstand strong temperatures and pressure.
- Weatherproof design.
- Five lighting modes: High , Mid, Low, Fast Strobe, and SOS Mode.
- Long lifespan
- Strong brightness up to 1000 lumens.
Features:
Modes: 5 Modes
Manufacture rate:
High: Operating current 3000mA, brightness 1000LM
Mid Mode: Operating current 1800mA, brightness 800LM
Low Mode: Operating current 900mA, brightness 300LM
Flash Mode: Operating Current 1500mA, brightness 800LM
SOS Mode: Operating Current 3000mA, brightness 1000LM
Memory: Circuitry Features Mode Memory
Mode Arrangement: High > Mid > Low > Fast Strobe > SOS
Casing Color: Black
Color BIN: White
Total Emitters: 1
Lens: Coated Glass Lens
Reflector: Aluminum Smooth/OP Reflector
Battery Configurations: 2 x 18650 rechargeable batteries (included)
Voltage Input: 4.2V~8.4V, 8.4V Max.
Switch Type: Clicky / Clickie
Switch Location: Tail-cap
Circuitry: Digital Regulated 3000mA Current Output
Brightness: 1000 lumens maximum brightness (manufacturer rated)
Runtime: 1 hour (manufacturer rated)
