Hi all,
I was in the middle of some driver/emitter temp testing when I noticed a puff of smoke come from my emitter and then it went out. I checked it and the positive lead from the driver to the star had come loose. I thought no big deal, the solder must have gotten to its melting point and came loose (I was in the middle of checking the temp at the back of the star when this happened and the emitter was being driven at 4.75A so the star was quite hot) So I soldered the wire back to the star and clamped it to my heatsink to check it out. Well the emitter would not light up. Checked for voltage at the pads and had volts there. I swapped out emitters and the new one worked fine. I dedomed the old one so I could see the bond wires better and they were in tact. I used my DMM in diode check mode and had nothing with + lead on + pad and - lead on - pad. But here is where it gets weird. I switched leads and the LED lit up. I hooked my PS up to the pads on the noctigon in reverse polarity and the LED lit up? How on earth does this make any sense beause I am lost on how a LED all of a sudden decides its going to switch its polarity. Any thoughts are very much welcome.
