Whoa bro!
Old style 1x18650 lights!
So where we can buy that?
Under testing, will release soon. Keep watch on weltool website ![]()
I like old school 1x18650 thrower lights without redundant parts like micro usb charging port and similar… I also hope they will not mess with driver UI to much; if someone wants 1000 modes that is ok and I respect that but there are people(hunters) that likes simplicity of usage like me so one mode only or if it is not possible high/med/low without memory effect so it always starts on high.
Yeah, hunters always like the simple and efficient lights. Well, these throwers have 3 mode, Middle(default) + High + Location beacom
Then I would like to buy host only and remake light for hunting purpose ![]()
good idea
How does that compare to a GT mini? arent the specs pretty much the same? esp the 130kcd ?
Probly better quality control (no dodgy switches & unpredictable behaviour & built to handle the lumens) ![]()
Weltool W3 too expensive?
Emmm, GT is battery direct-drive type flashlight without circuit control. Different battery will create different brightness.
GT's reflector is 43mm, T11's is 48mm, and GT's led is GREE, T11's is OSRAM. So I believe whether GT uses theoretical specs or T11 conservatively present its spesc![]()
Bro you know the ropes! ![]()
W3 LEP 's source is laser and T11's source is LED. With a larger head, T11 reach a distance about the same as W3 for more than 800m and its brightness can reach 800+ lumens that's T11s advantage. And of course, for its LED source instead of LEP, the price will be lower.
$260 at bangood
W3 is 260$ while T11 is 100+$ cause it uses LED not LEP resource.
