What construction product do I need?
I have an older house with a wooden detached garage (used just to store yard tools) and after the house was built at some point an idiot poured a concrete patio up against one side of the garage.
The garage is also lower than the patio so the concrete patio isn’t going up against the concrete garage foundation but rather against the wood siding.
So, part of it has decayed and I’m repairing that with some 2x4’s, plywood and cedar siding. I want to prevent this from happening again so what product would I look for at Home Depot to line the side of the patio.
I’m thinking some kind of aluminum flashing but it needs to be thin and something I can work with (I have tin snips) and there still has to be room for the wood siding.
Should I be looking in the roofing section for edge type flashing or is there some more appropriate product for this particular application?
My construction knowledge is limited so I thought I’d post here for some additional input. :slight_smile:
Aluminum roll flashing for roofing might do the trick. It comes in 10” and 12” widths and will isolate the wood from the concrete, but it must not be in contact with treated lumber or any of the corrosive liquids which will leach out of it. Copper flashing is available similarly but more costly (you may have to shop a roofing supply for that, don’t know if the ‘big-box’ stores have it). What will probably be your biggest problem is what you’re repairing now- wet rot- so use only rot-resistant woods and stainless fasteners in that area or you’ll be doing this again sooner or later! You’ll find me here under Mastercarpentry, my business name
Phil
