Modded my D18 with 18x 219B R9080 45K, maybe the brightest single 219B?
I also replaced all the optics with FP13028_LISA2-M-PIN (from Arrow) which has a wider LED opening and about the same beam width, maybe a few degrees wider.
Max regulated (14×7135) :
Output: 1,212lm
Spectral:
CCT = 4686K (Duv –0.0069)
Color Rendering Index (Ra) = 95.2 [ R9 = 98.1 ]
R1 = 97.9 R2 = 96.3 R3 = 91.0 R4 = 95.3 R5 = 96.3 R6 = 90.6 R7 = 96.1
R8 = 97.9 R9 = 98.1 R10 = 88.7 R11 = 94.3 R12 = 71.8 R13 = 97.7 R14 = 94.9
Yxy: 3226.395623 0.352368 0.343720
Turbo (3x not quite full 30Q’s): 7,714lm
Disassembly:
If you pull out the optics with tweezers you might want to use the grippy kind or wrap them in tape. If it slips at the top of the optic and closes it will leave a nice scratch (don’t ask me how I know).
Thermal transfer aint perfect but half of this giant MCPCB is good enough. My carbon steel crepe reflow pan on my induction stove top prepped for LED removal.
Stand by as I flip these bad boys onto the serving plate, stick a fork in them. You can also see the ridiculous amount of solder used. Almost as much as djozz does!
Reassembly:
A few important things here. Peppa pig precision electronics brush and alcohol. The saying goes measure twice cut once? Well I learned when modding to clean 47 times assemble twice.
I didn’t add any solder paste to the +/- pads considering how much was there already but I did use a toothpick and the smallest possible amount on the thermal pad. LEDs in position with my cathode marks all saluting me and wishing good luck. I have a video of part of the reflow but i need to edit it and speed it up. Needless to say it was uneventful, once it “flowed” I gave most of them 1 good tap and several that didn’t “look” centered got an additional tap or two.
What a relief, she works. Side note, based on Vinh’s video and the wires I had to desolder on the side I thought the MCPCB needed the 2 jumper wires connected but it doesn’t. I guess that is just to help even the current load? IDK.
The shelf still had a good amount of paste so I only added a touch to the more “open” areas of the MCPCB. Hope MX4 plays well with what Emisar uses. The LED wires and jumpers soldered pretty easily with a bit of flux paste on wire ends, dab of fresh solder on tip and 410-415C setting. Emisar uses great quality wires as always.
I put the two optics next to the jumper wires in first and just went to town. Don’t forget to clean your LED domes first, use a moon setting to see if you missed anything.
The trick to getting that clear O ring back on is this: Put it 3/4 of the way around that black PCB cover plate groove then for the last bit take the glass and place it on the O ring. Press on the top of glass and keep constant pressure as you slide the O ring into the remaining groove. Now your glass is slightly off center, keep pressing and re-center it, done!
